Fluctuating/jumping voltage on the board
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I am quite new at fixing boards and have one question that i couldnt find answer on the internet...What smd part/parts could cause jumping voltages on motherboard, and how to find them? I have this asus board that were shorted to the ground, i replaced dead 19v mosfets and now board is not shorted...but...when i use multimeter (with power on) on 19v net it is showing 19v stable (not fluctuating)...but on 5v,3v and 1v net the readings are jumping...on 1vsus it is jumping every second 0,23v, 0,78v, 1,2v, 0,75v, 0,27 v....and so on...same on the 5v and 3 v nets...Is it voltage regulator? mosfet? or? I tried to check with finger is anything heating a lot..but i couldnt find it...
    And one more thing... the multimeter is working fine (not broken) i test it on other working boards and voltage readings are stable.
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Fluctuating/jumping voltage on the board
    Upload the Schematic, remove one PAD of 5/3V each Coil PL and see whether the voltage is jumping maybe you have a Bad regulator IC 5/3V
    • m1ch43lzm
      by m1ch43lzm
      05-12-2025, 08:37 PM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • danny34
      E15 Gen2 Intel i5 - doesnt start & jumping voltage
      by danny34
      I have an E15 Gen2 with Intel i5 and need your help.
      It doesn't start and here's what I've already found out:
      All voltages are available.
      However, the PU8 (RT3612) does not switch the mosfets for +VCCIN.
      On the PU8 I measured 3.3V at pin 23 (VRON), but it drops to 0V every about 3 seconds. This voltage comes from the IT8227E.
      VCC from IT8227E has exactly the same symptom. Every 3 seconds the voltage briefly drops to 0V.
      In the end I saw that +1.8VALW (VCC from IT8227E), +0.6VS, +2.5V_DDR & +1.2V drop to 0V...
      12-13-2024, 04:20 AM
    • Hakuu
      by Hakuu
      Hi There,
      More Details
      TV Model - LG OLED77G1PUA
      07-12-2023, 02:37 PM
