Long Term Fate of Relatively Hot PCH
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Forum members,
    I have got a generic question.
    Sometime in some Laptops, I see some PCH chip that operates with a temperature between 70'C and 80'C because of weak heat sink. but never gets above 80'C.
    If I leave such a PCH chip to work in that condition with a regular laptop usage, what will happen to that PCH chip in long term?
    Does this temperature damage the chip?
    I have read datasheet of a few PCH models. it was mentioned there that the maximum operating temperature of PCH is about 105'C. But this temperature may be tolerated only for a short period.
    thanks
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Long Term Fate of Relatively Hot PCH
    From my experience, and from my research, I think we must distinguish two cases:
    1 the pch that is in the same chip as the CPU
    2 the single pch with or without heat sink
    In the first case the heat comes from two separate sources, from the cpu (on some cards the heat sink does not include the pch to avoid this problem) and the heat produced by the flow of the current.
    In the second case the heat is generated only from its operation
    and to a lesser extent from the temperature of the motherboard.
    How much temperature can it withstand and for how long?
    It is not easy to answer but I think there is also a problem
    of obsolescence programmed in the sense that perhaps the producer
    does not use all the technology available to make it work
    *as long as possible. I have soldered a very used pch (CM236 with many reballing and wrong solder temperature profile) and after
    seven months it works very well. For this reason , I think there is no correspondence between external heat and its damage.
    I think it's a matter of luck, it heats up because of a wrong motherboard design and is therefore more prone to internal failures.
    I think the cause is always an excess of current (which raises the temperature) and not the temperature itself.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      Thanks,
      The PCH chips which I observed were separate from CPU on 6-8 years-old laptops. Probably, those chips may be getting defective and get hotter than expected. But they still work. The temperature is generated by PCH itself.
      Now assume we have a new healthy PCH chip, that has no defect. but its heatsink is weak. how many years can it work under a regular laptop usage while PCH temperature be between 70'C and 80'C every time we turn the laptop on?
      Any experience please?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If the pch is really new, it should last atleast 3 years for HM70 Onwards chip. However, i see Older PCH like hm55 lasting longer.
        • CapLeaker
          AcuRite 5 in 1 temperature sensor replacement repair
          by CapLeaker
          Got a new victim:
          AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
          A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
          B: stuck at some temperature and maybe updating once in 12 hrs or so.
          Easy solution is to go to AcuRite website and purchase the sensor. Right?...
          04-15-2025, 01:32 PM
          40CPQ035 40CPQ040 40CPQ045 Datasheet
          The 40CPQ035 40CPQ040 40CPQ045 center tap Schottky rectifier has been optimized for very low forward voltage drop, with moderate leakage. The proprietary barrier technology allows for reliable operation up to 150° C junction temperature. Typical applications are in switching power supplies, converters, free-wheeling diodes, and reverse battery protection.
          Features
          - 150°C TJ operation
          - Center tap TO-247 package
          - High purity, high temperature epoxy encapsulation for enhanced mechanical strength and moisture resistance
          - Very low forward voltage drop...
          10-07-2024, 05:35 AM
        • asdas09
          Temperature to remove chips from motherboard
          by asdas09
          What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
          I have device Sugon 202. I'm used also normal flux and rosin flux.
          09-12-2023, 12:44 AM
        • Dreigas
          ISL95880HRTZ desoldering temperature
          by Dreigas
          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
          09-13-2024, 10:59 PM
        • jm1234
          9V relay temperature 40C
          by jm1234
          Hi, I'm seeing one 9V relay having temperature 40C on its 9V (primary) side. Does that seem right? I switched 2 relays on that board and the temperature was the same (on the same position), so I'm sure it's not a faulty relay. I measured voltage on that relay and it was 9.5V DC, so that looks good. I don't see any other relay on that board having that kind of temperature and they have 9V on them too.
          I thought maybe the transistor that is switching this relay keeps switching on/off, so I also checked for AC and there was almost none: 0.3V using mV range. No steady frequency was shown, but...
          05-09-2024, 03:03 AM
