A1466 MacBook Air
  • repairwhisperer
    noviceNerd
    • Jun 2019
    • 6
    A1466 MacBook Air
    I get orange light but will not turn on when battery is connected, only when battery is disconnected it will turn on. Is it the SMC? If so or not how do i test for a SMC failure? Any diode mode readings to look for?
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: A1466 MacBook Air
    Did you try another battery?
    Voltage on PPBUS_G3H and PP3V42_G3H with and without battery?
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • jheunne
      A1466 macbook no boot green to orange light help
      by jheunne
      i have macbook a1466 board id 820-00165 with power fan spin green to orange light not booting no image or light i tried to fix its leak chip number U1930 but sad it has been damage due of corrosion here i attach the image of board. possible there is a jumper ways for it can't find parts for it to buy.
      in first image there is 0v out for lcd
      https://ibb.co/5XppmpkH
      in 2nd image U1930 chip is damage is there any jumper solution or parts can be compatible for it
      https://ibb.co/fdJkbJs8
      06-10-2025, 10:52 PM
    • gboone
      820-00850 2019 MacBook Pro 13" Touch Bar (A1989) mysterious battery drain
      by gboone
      Hi, I was given this laptop by my uncle who said:
      • It would occasionally shutdown if not plugged in
      • battery had been replaced
      • touchbar would "strobe"
      I disconnected touch bar components and strobing and sudden shutdowns were fixed. Recent updates were installed to the OS.
      After fully charging the battery, with bluetooth disabled, no LAN cable and only wifi enabled, the laptop stayed on (screen on) for about 6-8 hours. Allowing screen to turn off while not in use, and it went for over a day.
      BUT
      When powered off, it would at some point have a...
      01-27-2025, 09:12 AM
    • mferna14
      MacBook Air A2681 battery problem after Screen Replacement
      by mferna14
      Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
      12-06-2024, 08:10 PM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
