3437 Low Res to Gnd on 3v42
  • BrickBreaker
    • 52
    I have a 3437 air board, ppbus was only 0.8V, 3v42 - 1.3V
    PPDCIN 3v42 - 15.55V
    Resistance to ground on 3v42 was 30 ohms
    KG board measured 22 kohm
    Started removing stuff and now I'm out of stuff to remove.
    I ended up removing ISL, SMC, U1900, U1950, debug, IO conn, tpad conn, U5110
    Checking resistance to ground after each component. 60 ohms now.
    I'm thinking it must be leaky to ground in the CPU or internal trace.
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: 3437 Low Res to Gnd on 3v42
    Liquid damage?
    Removed U7090 or L7095? U4650? There's also U3740 and then all the capacitors left.
    • BrickBreaker
      • 52
      Yes to U7090, forgot to list that one. I haven't removed L7095 but I removed C7099 and C7098. Now the only path to ground is through the feedback voltage divider which I checked earlier (haven't removed yet) but curiously both Ra and Rb measured 127 kohm??? Thanks for the suggestions, back to the chopping block.
      • BrickBreaker
        • 52
        No change after removing U4650, U3740, and R7096.
        • BrickBreaker
          • 52
          F me I knew when I found it it would be visibly damaged. I am the worst at using my eyes. Got to C5002 and yea it was burnt. Only a little but obvious to one of us. Thanks for the help, solved. Now to put everything back eeeee
          • piernov
            • Jan 2016
            • 4437
            • France
            Well at least you found it, good job, hoping it's the only issue with the board.
            • barry101
              Apple 820-3662 VCore shorted to ground.
              by barry101
              Hi, Would appreciate some help.
              I have an Apple Late 2013 15" A1398 MacBook Pro with Logic Board 820-3662.
              Get charger light but no fan spin or chime. No liquid damage.
              Found PPBUS and VCORE both shorted to ground. Other rails were ok.
              Removed VCORE MOSFETS U7310, U7320 and U7330. Found U7330 was in fact shorted.
              With the 3 MOSFETS removed, get PPBUS and fan spin. VCORE is still hard shorted to ground (0 ohms).
              Attempted voltage insertion on VCORE to locate short using bench supply set at 1.0 VDC and 4.95 Amps (max current for my...
              06-24-2025, 07:34 AM
            • Chaks
              Ground Plane For 5dBi ISM Band 865-870Mhz Embedded Ceramic Antenna
              by Chaks
              TAOGLAS ANTENNA MODEL: ISPC.86A.09.0092E
              The specs says ...
              High antenna efficiency 868MHz ISM Band
              5dBi Peak (when placed on 30cm x30cm ground plane) - Broadside to Zenith Radiation Pattern
              The antenna is 50x50 mm square and How do I fix it on the Ground Plane of 300 x 300 mm (aluminium sheet 3mm thick).
              1. Should I Fix it with a glue.
              2. Should I fix it with a double side adhesive tape
              3. Should I fix it with Screws (the screw head may just clamp the antenna to the aluminium...
              12-09-2024, 11:06 AM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
            • Rolin
              Dell Laptop - over 14V between Chassis Ground and Circuit Ground?
              by Rolin
              Someone brought me a Dell laptop that had a loose power jack inside (power jack on a cable, not soldered to motherboard). Once disassembled found one of the wires was broken off the power jack. I replaced the jack and it won't turn on, but the metal shell of the jack inadvertently touched the metal hinge and suddenly it got power. I checked voltage from the metal chassis ground and the circuit ground and I get over 14V ? Has anyone seen this before? Typically is it some kind of filter cap that shorted? Very strange...
              10-30-2022, 10:18 PM
            • kjchatman
              820-02020 a2338 motherboard has a ppbus short to ground
              by kjchatman
              this machine came to me as DOA and immediately found the issue as a 12v short to ground. Is it okay to inject voltage into that rail or does it have a potential path to the cpu or something?
              08-21-2025, 12:13 PM
