asus ux510uw wi-fi disabled by hardware
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    I I bought an Asus zenbook ux510uwk motherboard, all works fine except the wi-fi,
    there is a red X . (is very frustrating resend it to china)
    I have tried:
    1 - I don't see any wi-fi enable button, all fn+button works (light, etc)
    2 - two different windows 10 version
    3 - no driver issue
    4 - 3 different wi-fi adapter
    5 - on bios, wi-fi is unlock
    6 - bios dump
    7 - fn+f2 (all network disabled) works
    If I use automatic throubleshoot -> wi-fi is disabled by hardware
    Any suggest
    • 21022
    Re: asus ux510uw wi-fi disabled by hardware
    Are you sure its not a driver issue .Any problems in device manager
    UX510UW ATK,ASUS Wireless Radio Control,Qualcomm or intel wifi driver,Intel Serial IO I2C Driver
    Intel Serial IO GPIO Driver (for UX510UWK)
    Intel Wireless Lan Driver (for UX510UWK)
    • gabiz_ro
      • Mar 2011
      • 167
      • Romania
      If everything else is OK,last chance is something like that
      https://thecomputerperson.wordpress....-pin-20-trick/
      https://lybomudr.ru/en/132-zapuskaem...drugikh-2.html
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Thanks, I'm reading the links
        I forgot, bluetooth works well (same card)
        • jasko_jacker
          • Oct 2014
          • 1137
          • italy
          Just to consider all option, the pic show the three card I tried. The intel 7265 is the card I supposed original.
            • 21022
            8260NGW and AC7265 are the original intel cards. Does LAN work ok,are you getting a MAC address.
            EDIT: The UW model has an AC7265 and the UWK has the 8260NGW .
              • 21022
              Originally posted by gabiz_ro
              Thanks,thats good info .
              • jasko_jacker
                • Oct 2014
                • 1137
                • italy
                Send it to China is a nightmare but let's consider the situation on the side of a end user, he buys a card declared as new, mounts the card correctly, installs windows 10 (two version), installs all drivers from the asus site ...
                If the card works correctly (I must say that the serial number is not present in the bios and I think it should be present) there should be no problems, is it correct?
                  • 21022
                  Can you post your bios backup.The UW and UWK have 2 different bios. Does the boards silkscreen part number match with any part numbers on the stickers . Did you check LAN MAC address.
                  • jasko_jacker
                    • Oct 2014
                    • 1137
                    • italy
                    Actual bios is from DrBXXXX
                    ZenBook UX510UWK-F1_bios-version-300
                    this bios has a different layout respect bios for ux510uw (not lock_unlock button for wireless)
                    In the pics other details
                      • 21022
                      The LAN is missing in your pic on device manager. Do you have the MAC address on a sticker on the ram slot. I could try adding the mac to the bios manually but its easier to use asus bt2.exe tool .After adding a mac and getting an ip address through the lan ,the wifi may start working.
                      EDIT: i`ll post a bios to try. bios moved to - https://www.badcaps.net/forum/showthread.php?p=966610
                      EDIT: Added bt tool, zip password in pm .
                      • jasko_jacker
                        • Oct 2014
                        • 1137
                        • italy
                        BT2.exe seems don't work , no change mac , no serial
                        I'm trying your bios
                        thanks
                        • jasko_jacker
                          • Oct 2014
                          • 1137
                          • italy
                          With HEX editor I found the MAC location (2301C2h) on the old UX510UW bios, if the location is the same, I can put the same MAC on UX510UWK bios. Unfortunally the chinese guy has remove all labels on board so I don't have the original mac.
                          • jasko_jacker
                            • Oct 2014
                            • 1137
                            • italy
                            Last news,
                            I followed the instructions of the link, posted by @gabiz_ro,
                            and indeed wi-fi is on.
                            At this point I don't know whether to deliver it to the owner with this change. I also bought the original wi-fi card, Tuesday should arrive.
                            • jasko_jacker
                              • Oct 2014
                              • 1137
                              • italy
                              Good news,
                              I learned something else, this notebook accept only intel 8260 wifi card, otherwise it is necessary to cover two pins to enable wi-fi and BT.
                              • el panke
                                • May 2019
                                • 78
                                • argentina
                                thanx alot
                                • relax79
                                  • Jul 2014
                                  • 52
                                  • TURKEY
                                  Hi, thanks for sharing but I download bt.exe zip but I need password, can you send me in pm please, thanks.
                                    • 21022
                                    you can find bt.exe/bt2.exe here https://novoselovvlad.ru/2019/03/07/...transmit-tool/
                                    • relax79
                                      • Jul 2014
                                      • 52
                                      • TURKEY
                                      • grimacelord
                                        by grimacelord
                                        07-10-2025, 02:52 PM
                                      • anceng
                                        ASUS TUF Z390-PLUS GAMING WIFI REV 1.06
                                        by anceng
                                        Looking for ASUS TUF Z390-PLUS GAMING (WiFi) BIOS dump — rev 1.06, full 16MB SPI image with EC, I recieved a board without spi chip. I extracted and clean me using FIT on all asus provided cap and all are not working. please help
                                        08-02-2025, 02:29 PM
                                      • Olvin1
                                        Asus B760M-A WIFI d4 bios
                                        by Olvin1
                                        Good evening to everyone I'd like to ask you too much if you don't have a bios into the asus B760M-A Wifi d4 motherboard that could load directly into the winbond Bios chip downloaded from the Asus website can't be loaded onto the chip and I can't get it through the usb because the board won't be rolling at all .... Thank you very much everyone for your help
                                        04-04-2025, 04:07 PM
                                        ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                        This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                        09-07-2024, 02:50 AM
                                        ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                        This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
