Laptop only charges when off
  • Electrix78
    • Nov 2018
    • 15
    I am a computer tech, but not really skilled in PCB's and component fault finding although I am good with a soldering iron.... I have tried everything to get a customers laptop to charge, reinstalled OS, bought a new battery, new HDD reinstalled/reseated memory and CPU, disassembled laptop and replaced all heat transfer paste, checked plugs and sockets you get the idea, I am almost convinced that it is the charging circuit on the motherboard, but that's where my skills are limited. Anyone know what components on the motherboard are responsible for charging? or what may need replacing.
    The battery charges fully when the laptop is switched off, and it runs fine when plugged in but if you unplug it the battery depletes as it should but will not charge until you switch it off again.
    Look forward to the responses.
    Greg
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: Laptop only charges when off
    Tried another AC adapter? (compatible with the machine obviously)
    Also be aware that there are a lot of garbage batteries on the market lately. Not that uncommon to get 2 bad batteries in a row.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      You need to check all the fets connected to charging circuit. If everything seems fine, then need to probe charging ic.
      Btw, i dont think battery is faulty as it charges offline and gives backup also. though still it can be faulty but not very likely to be so.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3582
        • slovakia
        yesterday have one lenovo with just this problem. somebody changed charging connector cable but id pin was in wrong position/from another laptop with same connector/
        i just change position of id pin and everything works. so u should concentrate on id pin
        and offcourse u must post board type and mark
        • Electrix78
          • Nov 2018
          • 15
          Sorry,
          Forgot to mention, that I did purchase an original HP spare laptop charger for this model,
          mcplslg123 you mentioned to look at the charging IC, can you describe what it looks like or what kind of case style it might be? Thanks
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            you have not mentioned laptop model/mb markings-so its difficult to say which charging ic it uses. It is closely located near battery connector in most mobo's.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3582
              • slovakia
              get schematic and concentrate on ID pin circuit
              • Electrix78
                • Nov 2018
                • 15
                Sorry,
                Model: HP Pavillion DV6 Laptop
                Board: HP 181B 52.24
                BIOS: F2E
                I7 3610QM
                running win 10 8gb ram
                • zhang
                  • Jun 2017
                  • 50
                  • Indonesia
                  Originally posted by Electrix78
                  Greg
                  How is the charging indicator in windows?
                  plugged in not charging / plugged in charging
                  and make sure the adaptor is suitable
                  check the amperage of the adaptor output ( sticker on the adaptor )
                  and also check for the amperage input for the notebook ( sticker below the notebook )
                  or you could test with other tested good adaptor friend.
                  I suspect the adaptor amperage is lower than it needed to be "charge while power on state"
                  • Electrix78
                    • Nov 2018
                    • 15
                    Hey Zhang,
                    Laptop shows as plugged in not charging, I bought a 120w charger original HP spare part, the laptop only asks for a 90w so this should be more than enough to charge it. I have tried reinstalling back to win7 on a new HDD no luck at all
                    Thanks Greg
                    I think as mentioned by ktmmotocross I will concentrate on the ID circuit, and will post the results when I find something.
                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                      09-06-2024, 09:30 PM
                      Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 08:47 AM
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                      Microsoft Surface Laptop Surface Laptop Go 2 Notebook Go 2 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop Go 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop Go 2 boardview and Surface Laptop Go 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:11 AM
                      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
