Dell E5440 does not turn on
Re: Dell E5440 does not turn on
The bios region is 6MB so there will be a mismatch,flash both U1 and U2 .Comment
I flashed U1 and U2 but did not turn on, during programming the ch341a does not recognize the chip which according to the scheme are winbond w25q64 / 32fv, instead it reads them as ST m25p10a, I noticed that on the two chips there are no 3.3V_M I think without of these tensions cannot workComment
Ok they have used ST m25p10a Instead off w25q64 and for the second Bios most of the time Vin gets after but according to the schematics it's different maybe someone else can help on this Example SMDflea Or another veteranI flashed U1 and U2 but did not turn on, during programming the ch341a does not recognize the chip which according to the scheme are winbond w25q64 / 32fv, instead it reads them as ST m25p10a, I noticed that on the two chips there are no 3.3V_M I think without of these tensions cannot work
Thanks SMDflea do you have another DumpComment
Just the resistance to GND on the BIOS chip pin8 That doesn't have a powerI flashed U1 and U2 but did not turn on, during programming the ch341a does not recognize the chip which according to the scheme are winbond w25q64 / 32fv, instead it reads them as ST m25p10a, I noticed that on the two chips there are no 3.3V_M I think without of these tensions cannot workComment
U43 and U45 aren`t being swithed on,you need PCH_ALW_ON and A_ON from RP18 .Check RP18Comment
@Techtiger Thanks SMDflea do you have another Dump[/QUOTE]
Yes on this thread: https://www.badcaps.net/forum/showthread.php?t=70030
There are 2 different bios versions depending on the system configuration ,vPro/AMT and non-vPro . The bios at post #13 is vPro/AMT.Comment
Yes try it, make a backup first .Comment
I take this case again to try to reprogram the bios, I have a question: the bios chips are not winbond like the other two cards I mentioned, but they are from the ST micron U2 M25P10A 128k 1mb, I can always flash the same winbond bin file or is it different? comparing them they look the same but I'm not sureComment
I flashed again U1 and U2 without results, missing the + 3.3v on these two do not come out of U45, this is powered however it lacks SIO-SLP-A # that if I'm not mistaken it comes out from the micro-ec, I return the doubt that it is a bios -ec problem, what do you think?Comment
			by masoksianHi everyone,
I am dealing with the problem of turning on and off my Dell e7470 notebook.
The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
The system does not turn on, there is no post.
I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
The problem continues in the same way.
I tried to turn on the Fn key, nothing came to the screen.... -
			by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
			by Naineesh1I just recieved a working laptop for a quick dc port swap, i tested the laptop on battery it worked, tested dc port issue felt loose, so disassembled the laptop and removed battery connector, swapped the dc port, re-connected the battery connector, inserted dc pin, white led glowed up - stable, pressed power switch, but it didn't turn on, no fan spin and no display. just 1 white led that glows up, doesn't move to orange (charging), i check voltage (battery : 11.37v) (dc input port : 19.3v)(bios : 1.75), i am stumped, there is no shorting on board.
Schematic diagram : bios chip volt... -
			by javieromexHello, any help will be apprecited!
- Model: Dell G15 5511
 - MB: LA-K452P
 - Issue: Won't turn on at all, no leds, no keyboard light, no fan spin, nothing happens when pressing power button. NOTHING.
 - Customer reported it was turned off and left plugged in during the night and thats it...
 - No signs of liquid damage or burned components.
I have checked so far:
			by BenzohevThe laptop Dell Latitude E5520 oes not turn off - OS is loading.
I reflashed the BIOS; I removed the HDD, Wi-Fi module, DVD drive - I booted from a flash drive, sent the shutdown command - it turns off for a couple of seconds and turns on again! Maybe someone knows what to do?07-17-2025, 08:18 AM - Loading...
