Macbook Air 820-3437 - Random Re-boots
  • fred23456
    • Apr 2019
    • 14
    Got a Macbook Air 820-3437. Had liquid damage and has had quite a lot of repair work done on it to get it where it is now.
    It now passes everything in ASD and boots to the OS, all be it a little slowly, the loading bar on boot takes a few seconds and usually stalls at about 60%. Once in the OS everything is normal, computer runs as fast as ever and CPU idles at around 40 degrees C.
    After about 20-30 minutes the computer will turn off and immediately restart. Sometimes the "your computer turned off because of an issue" message pops up, sometimes it does not. Occasionally it restarts a few times in a loop before getting to the OS.
    Any help with what I can do to attempt to diagnose this issue would be much appreciated!
  • piernov
    • Jan 2016
    • 4437
    • France
    Re: Macbook Air 820-3437 - Random Re-boots
    Tried another SSD? (or external drive with macOS on it)
    Otherwise, not sure but could be ME region issue. Was the EFI messed with?
    Try to run Memtest too, you never know.
    • fred23456
      • Apr 2019
      • 14
      I haven't got another SSD unfortunately. Just tested it using ASD on a USB stick, selected all tests and let it run, it rebooted during that as well, twice in a row.
      The EFI is untouched and I just tried running memtest, computer shuts down before it has time to finish!
      • fred23456
        • Apr 2019
        • 14
        For anyone looking for a solution to a similar problem, this ended up being solved by the ultrasonic cleaner. I'm assuming it was corrosion under the SMC as suggested on another forum.
        • envym
          by envym
          Hi everyone!
          06-27-2025, 08:54 AM
        • MullySculder
          A1989 EMC3214 can't boot to USB drives due to T2 but SSD can't be initialized and Macbook freezes then reboots in recovery
          by MullySculder
          Hey folks, I'm working a 2018 13" Macbook Pro that I can't get to install an OS on.
          This was given to me by a friend who told me I could have it, if I fixed it.
          I've noticed a couple of dents on the laptop case and the touch bar doesn't have any activity lights when first turning on. When I boot up the machine, it gives a folder with a question mark. When I do eventually get to internet recovery with High Sierra, I can go to Disk Utility but I'll get errors when I try to erase the 512GB SSD. First Aid comes back with no issues. But if you linger too long on anything,...
          07-10-2024, 02:17 AM
        • tobeend
          Bypass mdm macbook m2 ventura
          by tobeend
          1. RESET MACOS WITH IPSW
          a. Power off MacBook, press and hold the power button to enter Recovery
          b. Open Disk Utility, remove Macintosh HD
          c. Reboot, connect to the network to Activate Mac.
          d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
          d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
          e. Release the other keys, but keep holding the Power key for another 10 seconds
          f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
          05-26-2023, 07:18 AM
        • SarcasticOP
          General question about MacBook power rails for repair.
          by SarcasticOP
          I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
          • PPBUS_G3H (12.6V-12.8V)
            • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
          • PP3V42_G3H (3.42V)
            • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
          • PPVRTC_G3H (3.3V)
            • This
          12-12-2024, 05:50 PM
        • roxboy1984
          Macbook Pro 13" M1 Reboots every 30 seconds
          by roxboy1984
          I wonder if anyone can assist. I have a macbook pro 13" M1 that had some liquid spilled on it. I have taken everything apart and cleaned with Isopryl and now the machine turns on but after about 30 seconds it will just shut off and start again. There is generally a pink screen that flashes just before it reboots.
          Anyone perhaps have any suggestions on what i can test or might need to replace?...
          03-06-2023, 10:31 AM
