Another G72 - 120SD with black screen
  • pecrie
    • Nov 2011
    • 182
    So , this G72 laptop has a black screen.
    DC in led is on and the fan is spinning.Voltages seem to be ok.
    But nothing on the screen (black) - no leds blinking on keyboard ...
    So I did flash the bios rom - W25Q32V - with the 1425F36_BID03651_Main. bin .And now the CapsLock and the NumLock are blinking 1 time (slow).
    That would mean that the CPU is faulty.I replaced the CPU but still the CapsLock / NumLock is blinking 1x
    Then I flashed the bios rom with the 1425F37 4MB bin.
    But still the same thing.The CapsLock / NumLock blink 1 x slow ...
    So , what next ?? Should I also flash the EC rom ??
    Because the EC BIN file is also in the zip file ??
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Another G72 - 120SD with black screen
    check for your DDR3 DRAMRST
    +VTT
    SIO Pin 31 87
    H_CPUPWRGD
    • pecrie
      • Nov 2011
      • 182
      Thanks I will check it
      • pecrie
        • Nov 2011
        • 182
        @techtiger ,
        What do you mean with SIO pin 31 87 (is it the IT8502 - ) ?
        • Techtiger
          • Oct 2014
          • 1602
          • france
          Originally posted by pecrie
          @techtiger ,
          Yep
          • pecrie
            • Nov 2011
            • 182
            @techtiger ,
            I must make a correction here.Seems I was still thinking about the other G72 with no life in it.
            However this MB has a ENE KB3926QF as SIO.
            So , any ideas what to check here ?
            Sorry for my mistake ...
            • Techtiger
              • Oct 2014
              • 1602
              • france
              @techtiger ,
              if you have the Schematic uplode it
              • pecrie
                • Nov 2011
                • 182
                This is the schematic that I have.But I'm not sure if it is the correct one.
                Because it does not mention the HM55 chip as Ibex Peak-M ...
                  • 21278
                  What is your HP bord number. Page 75 http://h10032.www1.hp.com/ctg/Manual/c02623152
                  • pecrie
                    • Nov 2011
                    • 182
                    Well this is the number that I found : 595183-001
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      According to your schematic DRAMRST is pin 30 on DDR3 slot, pin75 +1.5VSUS, Pin 75 DDR VTT 0.75V
                      • pecrie
                        • Nov 2011
                        • 182
                        techtiger ,
                        I will check.But I noticed that in the HP user manual they specify that the G72 should (only) have a i3 - 350M CPU (but I'm not really sure)
                        However in this laptop there is a i3 - 330M (I have replaced it with another i3 - 330M with the same result)
                        I now have bought a i3 - 350M (will see if that will make a difference)
                        • Dimitrios
                          • Nov 2013
                          • 127
                          • Greece
                          Any luck? I have the same problem. After showing some distortion in picture through hdmi connection it refuses to start. Just the power led on but nothing else. Did a quick reflow on the graphics chip but still nothing.
                          • pecrie
                            • Nov 2011
                            • 182
                            @Dimitrios ,
                            I don't want to make things more confused.Because I have 2 G72 - 120SD .one has the KB3926 and the other has the ITE SIO chip.
                            The one with the ITE chip is blinking 1x on the Capslock.
                            The other with the KB SIO chip is doing nothing - no adapter light white or orange.
                            I have just resumed to work on that one.So , the moderator put that post as a new thread in this forum.
                            I must say that the 2 G72 - have different MB with different numbers.
                            Maybe the moderator can delete the other thread - about the G72 - and we will use this one .....
                            • pecrie
                              • Nov 2011
                              • 182
                              edit : I have no solution for the black screen at this moment ...
                              • HTR-Informatique
                                Dell G3 15 3500 - Battery bug (black screen and flashing keyboard backlight)
                                by HTR-Informatique
                                YouTube video of the problem encountered: https://youtube.com/shorts/q7TLNv36LUo
                                I am a pro and I have a problem that I have never seen despite my 7.5 years of experience on my own and my thousands of repairs, on a customer's Dell G3 15 3500.
                                On this PC I have already changed the complete palmrest because the keyboard was no longer working properly.
                                I also changed the screen because the PC fell and the screen was broken.
                                I changed the battery with a new and original battery.
                                I also had corrosion/oxidation on the...
                                02-09-2025, 06:51 AM
                              • howardc64
                                by howardc64
                                Problem
                                08-04-2024, 10:36 PM
                              • DaniK
                                Acer Aspire E5-574-52RH - black screen
                                by DaniK
                                I have this strange behaviour with Acer Aspire E5-574-52RH, i5 6200U, intel graphics, DA0ZRWMB6G0 Rev G, model ZRW.
                                Laptop came in for a SSD upgrade, took everything apart to install the SSD.
                                Everything started after modifying BIOS settings to boot UEFI instead of Legacy.
                                Laptop works fine, i installed windows 10 and drivers/updates, everything works ok(when it works)
                                The black screen problem is random, maybe 5 out 10 times, laptop remains with the black screen, no image
                                Symptoms are:
                                - random black screen after displaying Acer logo...
                                02-21-2024, 06:27 AM
                              • turmix
                                AOC U34G3XM, new monitor, black screen with backlight on, possible shortcircuit during dissassembly
                                by turmix
                                Hello, I'm working on a new deskmod pc project and have a problem with my monitor, an AOC U34G3XM, well, I may have bricked it.
                                The monitor was dismanteled and the separate parts parts integrated in the desk. the screen panel alone is on the upper part, and main board/video board + power board on the back of the desk (not enough place on the cover to fit it)
                                At first everything was working smoothly, then I decided to change the connexion between the video board and the screen for a longer one. Still working fine
                                During another reassembly, I made a mistake, and...
                                01-29-2024, 03:48 AM
                              • Info13
                                Hp 15 laptop black screen with capslock blinking
                                by Info13
                                problem: trying to upgrade the memory the laptop turn on normally but it freeze before schowing the desktop. I force the shut down by pressing the power button and reboot it. But in this time the capslock blinking with 5 long and 3 short, nothing appear in the screen, it's black.
                                solutions trying:
                                - Remove the new RAM - booting with windows and B key pressing (nothing happened)
                                - update the Bios with usb (won't updating)
                                - remove the bios chip from motherboard and reprogram it with CH341A and *.bun file that was posted by a member in (bios request only section)...
                                01-01-2024, 03:19 AM
