HP 15 power led blinking .
  • mo000
    • Nov 2017
    • 285
    • algeria
    hi everyone
    i have HP with motherboard DAR62CMB6A0 rev:A
    the power led turn on and off (start and restart no fun spinning )
    3.3v on ec bios but not exist on main bios ,
    but after i press the power button the 3.3 v appears on main bios
    i try to flash the main bios but the bios programmer can't recognize it i try with different programmer and the same problem ; i think the bios ic(EN25Q32B) is damaged , i use MX25L3206E as replacement but the same problem .
    any idea .
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP 15 power led blinking .
    Usually on a R62 mb , dc jack light blinking is due to resistor failure. I solved this case few months back and it was resistor for sure. Dont remember exactly but the resistor was located somewhere between power switch and vga port. Hopefully, you can find out.
    • mo000
      • Nov 2017
      • 285
      • algeria
      it's not blinking , it's like the laptop boot and reboot
      • farouk25
        • Jan 2019
        • 23
        • algerie
        try to flash bios
        • pecrie
          • Nov 2011
          • 182
          Have you taken the main bios chip from the motherboard ??And then tried to flash it with the programmer ??
          What programmer are you using ?
          Sometimes it is not possible to program the bios chip (sitting on the MB) with a cable and a clip ...
          You may need (to buy ) another programmer to do it in this way ..
          • mo000
            • Nov 2017
            • 285
            • algeria
            yes i do
            i use RT809F
            • mo000
              • Nov 2017
              • 285
              • algeria
              any help please .
                • 21936
                try another bios,flash both files. https://drive.google.com/file/d/1LPE...DVvED41ix/view
                • STKR123
                  The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                  by STKR123
                  Greetings badcaps community,
                  I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                  So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                  Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                  I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                  These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                  I learned that desoldering...
                  10-29-2024, 06:03 AM
                • hotcrossedbuns999
                  M715q Desktop (ThinkCentre) - Type 10M3 - Request bios chip location and useable bios for use with CH341A Programmer.
                  by hotcrossedbuns999
                  My pc updated bios through Windows Update and I was greeted with BLACK SCREEN WITH CPU FAN MAX SPEED. I don't think there is even a screen signal, because it triggers my monitor for a couple seconds and then the monitor turns off. I tried the other outputs as well.
                  1. I tried clearing bios, resetting bios, removed the CMOS battery, removed m.2 ssd, wifi, and ram. Still black screen with CPU fan blasting.
                  2. I tried using the Lenovo BIOS CD and BIOS USB, but neither worked. At least I couldn't get anything to work.
                  3. I could only locate two chips that look like bios chips. Could someone verify this
                  01-03-2025, 12:32 PM
                • iulik17d
                  Intel Arc A380 videocard power limit remove - BIOS needed
                  by iulik17d
                  Hello everyone!
                  The Asrock A380 low profile card (ID 8086 56A5 - 1849 6006) have an power limit of 45W. Intel removed the possibility to increase power using the software utility, anyway the card is in an proxmox machine that doesn't run windows.
                  The same hardware is in another form by the name Asrock A380 Challenger that have the same VRMs and the power limit is at 60W. I searched online and found on another website an .bin bios file from the Challenger variant, that I flashed using an CH341a. Flashng worked well, I put the card in PC and booted. GPUz shows that new device ID is 8086...
                  01-10-2025, 02:33 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • PantherDave
                  by PantherDave
                  Hi all!
                  05-29-2024, 02:01 PM
