macbook pro retina 15inch a1398 power issue
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    here is something strange...it can start with power supply and runs fine and can charge also but with 85waat magasafe it could not turn on and green led on and again off on magasafe i tried with other adapter also same any ideas from where i should start ......i changed battery charging ic also same result no sings of water damage.....mobo code is 820-3787-a
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: macbook pro retina 15inch a1398 power issue
    Maybe an issue with R7012, around Q7010 circuit (shorted MOSFET, bad resistors or bad zener diode), or around Q7180 (shorted MOSFET or bad gate resistors).
    • monitron
      Apple veteran.
      • May 2014
      • 38
      • Holland
      If it starts on adapter, does the battery icon appear? You should first find out if it is a battery power problem or a battery communication problem.
      • alihomee
        • Dec 2012
        • 1594
        • malaysia
        it does not start with adapter it only turns on with power supply
        • alihomee
          • Dec 2012
          • 1594
          • malaysia
          can i get board view or schematic
          • peste
            • 13653
            • ROMANIA
            try ...
            https://www.badcaps.net/forum/showthread.php?t=62268
            • alihomee
              • Dec 2012
              • 1594
              • malaysia
              i checked around as mention above but circut is fine
