Asus G750JW Rev2.1 works on battery but not charger
  • alekk89
    • Nov 2015
    • 32
    • United Kingdom
    Hello guys,
    A friend of mine tried to replace his thermal compound and i don't know exactly what he did but PR8842 (10ohm resistor on the charger line) was burned. I replaced it but still doesn't turn on charger only.
    After the resistor is the charging ic, any idea how to check if it works properly?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3553
    • slovakia
    Re: Asus G750JW Rev2.1 works on battery but not charger
    that 10 ohm resistor have high amperage so u must have short after him
    • alekk89
      • Nov 2015
      • 32
      • United Kingdom
      Since it works on battery only i assume the problem is somewhere with the charging circuit. After the resistor comes directly the charging/power management ic.
      Any idea where should i look for short?
      • Techtiger
        • Oct 2014
        • 1601
        • france
        Since the Mob Working on Battery first check your first 2fets and the CLR Resistor Voltage, for the Fets test all legs Voltage May be your are not getting the Gate pass for the moment don’t change any components unless your sure, request the board View in Schematic Section
        • alekk89
          • Nov 2015
          • 32
          • United Kingdom
          PQ8801 -
          pin 1-3 0.5v
          pin 4 - 5mV
          pin5 - 19.7V
          PQ8802 -
          pin 1-3 0.5v
          pin 4 - 5mV
          pin 5 - 220mV
          Charger only connected, no battery
          *I have boardview, i don't have the schematics though
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3553
            • slovakia
            charging line did not comes directly to charger ic. it comes THROUGH that resistor to main 19V line. charger ic is just connected to that resistor to measure current by measuring voltage drop on him
            did u check resistance to ground on that resistor?
            • Techtiger
              • Oct 2014
              • 1601
              • france
              Originally posted by alekk89
              PQ8801 -
              pin 1-3 0.5v
              pin 4 - 5mV
              pin5 - 19.7V
              PQ8802 -
              pin 1-3 0.5v
              pin 4 - 5mV
              pin 5 - 220mV
              Upload the boardview pin 4 must be the Gate, Voltage on the Gate is too low
                • 20300
                Post #13 for the boardviews: https://www.badcaps.net/forum/showth...ghlight=G750JW
                • Techtiger
                  • Oct 2014
                  • 1601
                  • france
                  Originally posted by SMDFlea
                  Thanks SMDflea
                  • Techtiger
                    • Oct 2014
                    • 1601
                    • france
                    now test voltage on PU8800 pin 4 ACDRV 20 to 25V ?
                    voltage PR8809 both sides ? PC8805 both sides ?
                    • alekk89
                      • Nov 2015
                      • 32
                      • United Kingdom
                      PR8809
                      Pin1 - <20mV
                      pin2 - <10mV
                      PC8805
                      Pin1 - 19.7V
                      Pin2 - <20mV
                      PU8800 pin4 - <10mV
                      I checked for short to ground on both sides of the resistor before replacing, no short.
                      • Techtiger
                        • Oct 2014
                        • 1601
                        • france
                        PR8809
                        Pin1 - <20mV
                        pin2 - <10mV
                        PC8805
                        Pin1 - 19.7V
                        Pin2 - <20mV
                        PU8800 pin4 - <10mV
                        PU8800 pin 4 volage must be +20V ok now test same IC pin 20 1 2 5 6 16 and pin 4 Ohms
                        • alekk89
                          • Nov 2015
                          • 32
                          • United Kingdom
                          PU8800
                          All resistance measured directly on the pins to gnd
                          Pin1 - 2.46k
                          Pin2 - 2.46K
                          Pin4 - 0L
                          Pin5 - 0.66M
                          Pin6 - 17.2K
                          Pin16 - 135K
                          Pin 20 - 0.484k
                          • Techtiger
                            • Oct 2014
                            • 1601
                            • france
                            PU8800
                            Pin1 - 2.46k
                            Pin2 - 2.46K
                            Pin4 - 0L
                            Pin5 - 0.66M
                            Pin6 - 17.2K
                            Pin16 - 135K
                            Pin 20 - 0.484k
                            Same pins Voltage's expect pin 4
                            • alekk89
                              • Nov 2015
                              • 32
                              • United Kingdom
                              PU8800
                              Pin1 - 350mV
                              Pin2 - 350mV
                              Pin5 - 20mV
                              Pin6 - 2.6V
                              Pin16 - 11.5V
                              Pin 20 - 18.9V
                              • Techtiger
                                • Oct 2014
                                • 1601
                                • france
                                pin 1 ACN 20.3
                                pin 2 ACP 20.3
                                pin16(regn) should be 6V
                                pin 6 ACDET@2.87
                                pin 5 ACOK@0V
                                pin 4 ACDRV should be 19v+6v approx
                                second DC-in MOSFET (towards the system side) test for shorted (gate/source/drain) with the help of multimetre
                                • on/off
                                  • Oct 2016
                                  • 333
                                  • Indonesia
                                  HPA02196RGRR or BQ735 need acok high / 3.3V
                                  only ac_in_oc# required low signal / 0V
                                  • mcplslg123
                                    • Jun 2015
                                    • 7262
                                    • india
                                    correct
                                    • Techtiger
                                      • Oct 2014
                                      • 1601
                                      • france
                                      correct
                                      thanks
                                      • alekk89
                                        • Nov 2015
                                        • 32
                                        • United Kingdom
                                        No short on either of the mosfets (PQ8801, PQ8802)
