hp x360 not charging battery
  • jesi
    • Jul 2013
    • 71
    hi there
    hp x360 bucks uma mb 16872-1 448.0c204.0011
    all working on the charger
    all works when charger pin removed battery takes over and works
    but only will not charge battery stuck on percentage ?????
    so far changed to new battery , changed charger , also changed bq24737
    the only thing i dont understand that it has 2.6v on scl and sda on battery ??
    on this mb its using 2 sot23-6 fets on the scl sda ???
    also one sot23-6 has the marking of k702 which i think its a 2n7002 and the other has marking of C9 7H1 ???????? any idea what it is
    help required
    thankyou in advance
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: hp x360 not charging battery
    Originally posted by jesi
    hi there
    help required
    thankyou in advance
    Upload the Schematic, test all pins of the battery connector of MB for voltage with battery & without battery, test impedance of all pin of battery connector
    • drewrox2009
      • May 2016
      • 14
      I am having this exact same issue on a different board. 15M-BP111DX same bq24737, no schematic available for this board. Not sure where to look, and pulling my hair out!
      • Techtiger
        • Oct 2014
        • 1602
        • france
        First check AD_ID the middle pin of the charger is recognize by the mob
        Voltage on all pins of the battery connector 8 pins 2 or more GND pins
        • drewrox2009
          • May 2016
          • 14
          ac_id pin outside of laptop is 19v connected to mobo only .5v.
          up to today i was geting 0v on acok which for this model is good, now i am no longer getting light on dc cable. now getting 3.4v on acok.
          battery pins with no battery installed 0, 0, 123mv, 2.9, 3.1, 0, 0, 0
          battery pins with battery installed 11.5, 11.5, 123mv, 2.9, 3.1, 0, 0, 0.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Perhaps bq737 got damaged while measuring voltages on its pins. I'll suggest to replace it first and see if acok goes low again.
            • drewrox2009
              • May 2016
              • 14
              it probably did, i have replaced it as well. spend way too much time measuring that area. I was sure there was an issue with it or the passives nearby lol. actual issue was on the other side of the board.
              but it was good practice working on a board with no schematics
              • brew99
                • Jan 2019
                • 132
                edit: nevermind, found answer in other thread
                So what was the issue that you found on "the other side of the board", that seemed to fix it?
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                  ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                  Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                  The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                  for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                  Narrow VDC applications where the system power source is
                  either the battery pack or the regulated output of the charger.
                  This makes the max voltage to the system equal to the max
                  battery voltage instead of the max adapter voltage. Operating
                  at lower system voltage can improve...
                  11-05-2024, 04:43 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                  Bauer tool battery pack charging with a HERCULES charger modification
                  by sam_sam_sam
                  The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                  Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                  05-06-2023, 12:17 PM
