Asus x751lk - first repair attempt
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: Asus x751lk - first repair attempt
    Originally posted by alloallo
    Schematics attached
    SIO IT8585E
    I have measured the point you wanted. All the volts are as you wrote.
    the most top coil in the yellow is 16.8v
    voltage on smaller caps at rams are 0.7v. At the biger ones there is 1.4v
    test U3001 pin 68 ALL SYSTEM PWRGD 3.3V try to flash BIOS
    • alloallo
      • Mar 2019
      • 13
      • Slovenia
      yes that pin has 3.3v
      I have ordered bios programmer.
      As soon as arrives I will try to reflash the bios.
      • alloallo
        • Mar 2019
        • 13
        • Slovenia
        Ok little update.
        I got the programmer, programmed bios with bios file provided in https://www.badcaps.net/forum/showthread.php?t=60869
        but it's the same.
        But I have notice something when I plug in charger, there is quiet fast beeping coming from somewhere on the motherboard. I really can't locate the source of this beeps, but when I power on laptop beeping stops.
        Any suggestion on what could make theese beeps (it's not adapter itself).
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3628
          • slovakia
          check schematics for s5 voltages. its voltages that is present when attach adapter. if u have some of that beeping, i assume something is try to start but detect problem and power off and try another start
          also try at least 3-4 bioses
