need dump bios asus R752L
  • toufik sat
    • Feb 2016
    • 134
    • los angles
    BOARD NUMBER
    x751lk MAIN BOARD REV 2.0
  • durgesh
    • Feb 2017
    • 7
    • india
    Re: need dump bios asus R752L
    what is ur need
    • techman1025
      • Jun 2014
      • 497
      Hi upload original file and i will give you a working file in return .It's needed if somebody just uploads a donor file it will be dirty... and computer will either reboot ...fans racing and so on ...so i will remove your ME REGION and add it to a clean update. ASUS updates are not full size file. like acer and other companys.
      Techman1025`
      • cacla
        • Apr 2015
        • 442
        Here working bin it have one fix in there it disable SATA Device Sleep
        • cacla
          • Apr 2015
          • 442
          Sorry here
          • teknoturk78
            • Feb 2012
            • 10
            orginal asus R752L
            • Citymin
              NT955XED (Samsung Galaxy Book2 Pro - 15.6) BIOS dump file Request
              by Citymin
              My Samsung Galaxy Book 2 Pro 15.6-inch laptop has no display and won't boot.
              The charging red LED lights up, but the charging screen doesn't show any indication.
              When I press the power button, the blue LED cycles on and off three times, then the screen doesn't turn on, and the device won't boot.
              (I've tried removing the battery and resetting the device, but the issue persists.)
              NoteBook Model name : Samsung NT955XED-KK51G(Galaxy book2 pro, i5-1240p, 15.6inch AMOLED)
              PCB model name : Venus2-15-5G(REV1.2), Venus2-15 ADL NPC
              S/N : 5RNK9FFT70...
              08-05-2025, 05:12 AM
            • Sebastian Codrean
              BIOS file for ASUS F542UN laptop
              by Sebastian Codrean
              Hello to all of you! I need help with a BIOS file.
              The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
              So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
              02-20-2025, 10:25 AM
            • DynaxSC
              Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
              by DynaxSC
              I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
              The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
              Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
              Usually on ASUS boards it worked...
              06-14-2024, 03:49 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • kodox
              Asus ExpertBook B1400CB Bios Dump Needed
              by kodox
              need original bios dump, original bios has flashed by other technician before me.
              attached bios was read from the chip but no display and amperage fluctuating from 0.6A to 0.34 and back to 0.6A.
              unit info:
              Model: Asus ExpertBook B1400CBA-0711A1235U
              S/N: R6NXNZ006657238
              CN: 7F6F
              Mainboard Code: B1500CBA R2.1...
              08-16-2025, 12:20 PM
