Asus x751lk - first repair attempt
  • alloallo
    • Mar 2019
    • 13
    • Slovenia
    I am trying to do my first repair. I have motherboard of asus x751lk rev 2.0
    When I plug in the charger computer turns on, fan spins, but there is no image on the lcd or hdmi/vga output. Also the cpu and gpu are getting warm.
    I have this area where is something is shorted to ground.
    every other contact is shorted (some marked on the picture with squares) and it gives about 0.9v while on not shorted pins I get 19 v.
    I would like to have some advice on how to proceed.
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3597
    • slovakia
    Re: Asus x751lk - first repair attempt
    please stop repairing and give it to someone that have some skill and knowledge.
    what u see is mostly CPU power circuit. and 0.9V is absolutely ok, it is not shorted. if it was shorted the main power rail will be turned off
    dont proceed further because u dont have basic knowledge of this
    u must as first learn basics to be able to understand what is going on in this circuit
    • alloallo
      • Mar 2019
      • 13
      • Slovenia
      well I am just trying to learn
      Looks like I am not on the right forum. Mods you can close this topic.
      thanks for your help anyway.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3597
        • slovakia
        if u want to learn u must start with basics to be able to understand how it works
          • 20972
          The problem could be the bios ,do you have a bios programmer .
          • Techtiger
            • Oct 2014
            • 1602
            • france
            I agree with SMDFlea most likely BIOS issue check all the Big Gray Coils for Voltage and tell us what’s missing, try to find basic knowledge of how SMD component working & testing@ how to used multimeter
            • mosfetratus
              Sure Not
              • Feb 2019
              • 174
              • Resistron
              Could be faulty RAM too. Or just need to reset them in place.
              • alloallo
                • Mar 2019
                • 13
                • Slovenia
                Originally posted by techtiger
                I agree with SMDFlea most likely BIOS issue check all the Big Gray Coils for Voltage and tell us what's missing, try to find basic knowledge of how SMD component working & testing@ how to used multimeter
                I have checked all the coils and all the voltages seems to be present
                1.4 around the disk port
                0.9 2-coils around the nvidia gpu
                1.7 around the cpu
                3.3
                5.0
                bios chip has 3.3 (if that matters) at pin 1,2,3,7 and 8 when the computer is on.
                I have tried with and without the ram (it has 1 stick and 8 pads soldered directly on the motherboard.
                • alloallo
                  • Mar 2019
                  • 13
                  • Slovenia
                  any suggestion where to start?
                  • alloallo
                    • Mar 2019
                    • 13
                    • Slovenia
                    Not yet, but I'm looking to get one from ebay
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3597
                      • slovakia
                      what gpu u have in it?
                      • alloallo
                        • Mar 2019
                        • 13
                        • Slovenia
                        It has GTX 870M N15P-GT-A2 (soldered to the motherboard)
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3597
                          • slovakia
                          that can be problem. if u have allpwrgd signal
                          but with that great laptop i dont recommend u to repairing it for yourself. better give it to good service where is able to reball GPUs. they do diagnose and if it is in GPU they can reball it
                          • alloallo
                            • Mar 2019
                            • 13
                            • Slovenia
                            OK.. I will try to get someone who will reball the chip for me.
                            Will post the results here.
                              • 20972
                              Flash a new bios first, rule out the easiest things .
                              • alloallo
                                • Mar 2019
                                • 13
                                • Slovenia
                                any suggestion for bios programmer?
                                Ebay has unlimited options available
                                • ktmmotocross
                                  Boardkiller
                                  • Feb 2014
                                  • 3597
                                  • slovakia
                                  cheapest CH341A will be enough, but check if u have 3 or 1.8V bios chip and if u have 1.8V buy it with adapter for 1.8V
                                  on ali is about 2euros
                                  and offcourse u will need solder iron or beter hotair station
                                  • Techtiger
                                    • Oct 2014
                                    • 1602
                                    • france
                                    1.7 around the cpu
                                    3.3
                                    5.0
                                    test this points , what is the SIO IC ITEXXXX any one have the Schematic for this Mob,try to flach bios
                                    • alloallo
                                      • Mar 2019
                                      • 13
                                      • Slovenia
                                      Schematics attached
                                      SIO IT8585E
                                      I have measured the point you wanted. All the volts are as you wrote.
                                      the most top coil in the yellow is 16.8v
                                      voltage on smaller caps at rams are 0.7v. At the biger ones there is 1.4v
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        I agrre with @smdflea. It seems like bios issue.
