Panasonic CF-C1 no 5V on usb ports
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Good morning, this laptop has USB ports that does not have the 5V
    do you have any idea if recoverable or is the chipset
    TOUGHBOOK cf-c1 i5 mainboard DFUP 1999zc
  • DynaxSC
    GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
    by DynaxSC
    I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
    There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
    The board is generally working now, all PCIe ports are working, Windows installs normally.
    However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
    The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
    03-10-2025, 12:27 PM
  • aa10aa10
    Panasonic Toughbook CF-33 mk1 BIOS repair
    by aa10aa10
    Good day,
    I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
    I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
    01-21-2025, 06:13 AM
  • AquaMan Ua
    Panasonic toughbook CF-19 help connect the HDD directly. Need a SATA pinout.
    by AquaMan Ua
    Hello, dear community. NEED A DIAGRAM of the HDD/SSD connector contacts as an example (a screenshot from the diagram of another laptop on which I have already done this and a photo of the patient's board) Maybe someone can make a screenshot of the diagram with the pinout? Or does someone have a diagram of the motherboard schematic?
    I am asking, because not find the information myself anywhere. I have a PANASONIC CF19 MK2 laptop (Any revision will do, I do not think that the contacts in the connector are located differently) but finding a basket for it at reasonable prices is a problem....
    08-26-2025, 09:07 AM
  • eukal
    Panasonic toughbook cf-h2 Mk1 no power, 3.3v-5v present but no 3v on bios chip
    by eukal
    Hello, i have a Panasonic Toughbook Cf-H2 Mk1 that won't power on. The battery charge without problem but no response from the laptop when i press the power button.
    I have disassemble and unpluged the cmos battery, same no power on on battery with and whitout the adapter, and only adapter
    I have check the voltage i have the main power rail ( +-16v normal for toughbook it's not 19v). I have on the coil after power management chip 3.3v and 5v.
    I have check the 3.3v on the power button ribbon cable attach to the motherboard and the voltage go to 0v when i press the button. So...
    07-01-2023, 01:00 PM
  • Nedim Merdan
    Panasonic toughbook CF-D1DW200FZ motherboard DL3UP1969CAA schematic
    by Nedim Merdan
    Does anyone have the schematic for toughbook cf-d1 mk1 motherboard model is DL3UP1969CAA thanks in advance
    12-07-2024, 02:22 PM
