Asus E502M ( No 3.3V On bios Chip
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Hi guys need some help on this one got an Asus E502m with All the power supplies checked out and Working but on pin 8 of the bios chip im only getting 1.8V instead of 3.3v I have asked for a schematic in the schematic section but no reply yet so i can trace it .any ideas on how to troubleshoot this one.. Thanks
    Your never to old to learn
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: Asus E502M ( No 3.3V On bios Chip
    some Bios ICs require 1.8V instead of 3.3v.
    • garrymc123
      • Apr 2010
      • 336
      • United Kingdom
      Thanks Caspain for this information. what can i check next to see why it is not booting up..
      • brew99
        • Jan 2019
        • 132
        Take a look at this link for what might be the proper boardview file for your board
        https://www.badcaps.net/forum/showth...ghlight=e402MA
        Also look up the BIOS chip and see what the required operating voltage is (I'm at work so cant check boardview for you, and cant read it in the photos you posted). It is probably a Windbond chip of 8M. If it requires the 3.3V then you are on the right track to chase that down.
        • on/off
          • Oct 2016
          • 333
          • Indonesia
          Probably the bios chips is W25Q64FWxx
          Good idea is read datasheet when face new IC or first time to face with mobo want to fixed
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            Yip its a W25Q64FW 1.8v so where do i go next if i have all power supplies working but still wont turn on..Thanks
            • garrymc123
              • Apr 2010
              • 336
              • United Kingdom
              Anyone?
                • 20938
                Check the power sequence and test points .
                • BMCappelletti
                  Asus Chromebox CN62 - wrong chip put on BIOS reader
                  by BMCappelletti
                  Long story short:
                  - dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
                  - gave the computer to his son a couple years later
                  - son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
                  - too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
                  (seems like the story was not that short)
                  He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8...
                  01-08-2025, 07:27 PM
                • DynaxSC
                  ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
                  by DynaxSC
                  Hi
                  I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
                  08-04-2025, 12:20 PM
                  by SMDFlea
                  Bad...
                  09-02-2021, 04:40 PM
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • JoWed
                  Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
                  by JoWed
                  Hello Community,
                  I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
                  07-01-2025, 09:32 AM
