HP 4540s CapsLock continously blinks
  • pecrie
    • Nov 2011
    • 182
    S I have this 4540s from HP.When powering on the Caps Lock starts to blink.
    The wifi led is orange and the led next to it is white.
    I have read that it is something with the power supply.
    After a 6 seconds the fan starts to turn slow than high speed.
    I did not check voltages at this moment.But I did the 30 sec press power button - took out battery etc.
    Nothing is changed.
    Looks like there may be some mosfets defective or even the CPU - it should have a i5 - must verify if its the correct one.
    So any ideas ??
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Re: HP 4540s CapsLock continously blinks
    Have you tried another RAM module?
    • R_J
      • Jun 2012
      • 9535
      You could have a corrupt bios, Seems to be a common problem.
      • pecrie
        • Nov 2011
        • 182
        @caspian
        I took all the RAM modules out.It makes no difference.Without a keyboard connected , no HDD , no difference.
        At start the CapsLock starts blinking.
        I will check some voltages , but all seems to be good.Except the power led is not on when I plug in the adapter.
        It just briefly lights up then goes out when plugging in the power adapter.
        Yes it can be a bios issue too.But first I will check some mosfets etc
        • piernov
          • Jan 2016
          • 4435
          • France
          I have a 4540s where everything works perfectly fine except for DC-in light so I wouldn't rely on it (never found the issue). It goes to amber when charging the battery though
          For the caps lock blink usually there is some sort of pattern and it may give some info on what's the issue.
          • Udemzy
            • May 2017
            • 161
            • Guatemala
            Flash main bios, bios is corrupt.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The led in your dc jack is likely to be bad. Did ou tried another dc jack??
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Agreed, in most of the cases it is corrupt bios.
                • pecrie
                  • Nov 2011
                  • 182
                  On the input jack I have all voltages - 3.3 - 5.2 - 19.2 Volt
                  The white led on the power jack lights up for 1/2 second then goes off.For very very short time it is also orange.Then no more light.
                  I can not find the MB number and Version on the pcb board.It is a HP Probook 4540s
                  The RAM is a 1333 type (don't know if that is correct) -
                  But for now I want to flash the Bios - Bios chip is >> Winbond 25Q64FVSIG - 1231
                  Any ideas what type of bios firmware I need for this MB ??
                  Do you guys know what Intel processors can be fitted in this MB / And RAM ?
                  Or can you send me to a link with the 4540s specifications ??
                  Thank you
                    • 20949
                    "Or can you send me to a link with the 4540s specifications ??"
                    Really, all you need to do is google "4540s specifications" .https://support.hp.com/gb-en/document/c03349886
                    To find the MB number if you can`t find one on the board just search on ebay or aliexpress for "4540s motherboard" ,sometimes in the description will be a motherboard name Compal LA-xxxx or similar,and a picture with the number, sometimes its hidden under a sticker.
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      Motherboard of 4540s is Wistron Richie, schematics is available.
                      For the BIOS, ask in the BIOS request subsection or search on the forum if good dumps have been posted already.
                      Also this board may have a dead GPU (216-0833002 I think it was?), they have a high failure rate.
                      @mcplslg123 it's offtopic but yes I replaced DC-in jack, EC, checked resistor and transistor for the LED and everything is good.
                      • pecrie
                        • Nov 2011
                        • 182
                        Update on 4540s CapsLock blinking :
                        @SMDFlea : thank you , yes I did find the specifications for the 4540s via Google.
                        So , I decided to flash the Bios chip.I used the dumped bin file from SMDFlea with the DMI info in it.
                        With this firmware the CapsLock blinking was gone , but instead I got the white led in the power jack , that started to blink.
                        Did the usual checks and tests - 30 sec press power button etc , but it did not help.I also measured some voltages and checked some mosfets.
                        After this I decided to flash the bios again but now with the bin file from MarcellDJ.And what do you know : it works ..... )))))
                        I got the no bootable device found - HP UEFI etc .....
                        So it seems that the bios got corrupted at some point .....
                        BTW - I found that a blinking white led on the power jack has to do with putting the laptop into hibernation , while there is not enough charge on the battery (this is not the 3 Volts bios battery)
                        To fix this you must scan the computer with the tool Reimage Repair
                        http://www.digitaltechglobal.com/hp-...-flashing.html
                        But I'm not sure if this is an advertisement or a tool recommended by HP
                        @piernov - the CapsLock was blinking constant ( intervals - so no indication for a specific error )
                          • 20949
                          That "Reimage Repair tool " is a scam . You should always try to backup the bios first before flashing,it may/will contain some DMI info, and quite often a corrupt bios can be fixed.
                          • pecrie
                            • Nov 2011
                            • 182
                            No , I didn't use the Reimage Repair tool.And I did not download it either.
                            I was not sure if it was a good thing .....
                            Yes , I made a backup of the Original bios file .....
                            • modtool
                              HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                              by modtool
                              Hi to all,
                              the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                              I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                              I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                              04-01-2025, 08:22 AM
                            • Tom_x
                              HP Omen 15-dc0001nh capslock blinks 5 long and 3 short
                              by Tom_x
                              I have HP Omen 15-dc0001nh (DA0G3DMBCE0 rev: E) with blinking capslock 5 long and 3 short. Fans spin constans speed.
                              HP worked for 2 months after i repaired (before damaged by thunder via rj45 port) I removed LAN ic and powered on
                              Now with blinking capslock:
                              All voltage present on big coils, except +VCCGT (i don't know this need for booting)
                              I tried re-flash bios with known firmware- same result (now i don't have spare bios chip to test spi flash failure)
                              DDR4 ram is ok, tested on other laptop
                              WLAN and SSD removed,...
                              07-20-2023, 10:10 PM
                              HP ProBook 4540s Notebook 4000 Specification for Upgrade or Repair
                              This specification for the HP ProBook 4540s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4540s boardview and 4540s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4540s...
                              09-06-2024, 05:27 AM
                              HP ProBook 4540s 4000 Specification for Upgrade or Repair
                              This specification for the HP ProBook 4540s can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 4540s boardview and 4540s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP ProBook 4540s is accurate,...
