LA-6911P discrete to UMA
  • piernov
    • Jan 2016
    • 4439
    • France
    Acer 7750G, board Compal LA-6911P with (obviously) a dead 216-081005.
    Does anyone know the procedure to convert from discrete to UMA? Couldn't find any info on the web, schematics is available and lists the different BOM options, but there are no boardview. I could figure out some resistors and stuff but maybe not all of them, and I don't know if there it something else to mess with.
    The board is configured for discrete and LVDS (not eDP).
    Thanks;
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: LA-6911P discrete to UMA
    since there is no tutorial on this, you should go forward using the try&error method. first move R609 to R610 and R396 to R401. I guess these two movements might be enough. If not so, try some other options too.
    to find the resistors, take a look at this Russian page:
    translate.googleusercontent.com/translate_c?depth=1&hl=en&prev=search&rurl=translate.google.com&sl=ru&sp=nmt4&u=https://ascnb1.ru/forma1/viewtopic.php%3Ff%3D231%26t%3D96097%26start%3D0&xid=17259,15700021,15700186,15700190,15700248,15700253&usg=ALkJrhj-YsT5pJl6uSjx_rmaey_F2-HWuA
    it may help.
    In addition, I heard some revisions of LA-6911P are different from the schematics.
    • alderick
      • Jun 2015
      • 77
      • france
      I would like to know if you had any success with that modification?
      I have the same board with a dying GPU and I want to go to UMA too.
      Thanks.
      • piernov
        • Jan 2016
        • 4439
        • France
        Unfortunately not, not enough information on the Internet about this one. From a quick look at the schematics, it looked like there was a lot of components to swap (resistors to connect LVDS/VGA connectors to PCH instead of GPU and other stuff).
        I ended up buying a UMA only board, sold as defective but it was actually working. For 20€ it was definitely not worth wasting time to try to convert the original board to UMA and probably fail.
        • alderick
          • Jun 2015
          • 77
          • france
          Ok thank you.
          I'm not going to wasting my time so
          • Abdulrahman
            • Apr 2019
            • 9
            • turkye
            https://www.youtube.com/watch?v=q8VcDjJbU-A
            • alrep
              • Sep 2017
              • 8
              • Russia
              Rh551---rh552
              rh553---rh554
              • highpulse
                i hate HP
                • May 2013
                • 1490
                • portugal
                edited post :
                • pablobuma
                  • May 2014
                  • argentina
                  https://www.youtube.com/watch?v=sNqIhNyINCA
                  • TinkerTron
                    Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                    by TinkerTron
                    Hey everyone,
                    I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                    Instead, here's what's been bugging me so far:
                    The schematic...
                    03-06-2025, 02:03 PM
                  • brightest_z
                    Hot Air Blew Away Resistors Near Bios
                    by brightest_z
                    Hi All - I'm in the midst or reprogramming the bios on my gen1 Surface Laptop Studio and I accidentally blew away 2 resistors nearby the bios. I don't have another board to measure values of the missing resistors and schematics aren't available, bbut the bios is a 6x5mm Winbond WSON8, W25R256JWPQ model. The traces are conductive to Pins 3 and 7 (IO2 & IO3 respectively) so I have reason to believe they are 10k pull up resistors since IO2&3 pins are used for Quad SPI instructions.
                    Does anyone with more knowledge, and experience than I, know if this is the case?
                    12-11-2024, 08:34 PM
                  • jinu_j
                    LED driver circuit. Burnt Resistors
                    by jinu_j
                    Hi Folks
                    This has to do with a LED light driver rated for Output - DC36-65V 300mA. This is used to drive a 15W LED panel light.
                    Now this does not work so opened up and found 2 resistors burnt to crisp. Sensing a learning moment, i looked around the circuit to figure out that it is built around the OB2538 chip. The circuit to a large extent follows the sample application circuit mentioned in the data sheet. I have traced the actual circuit and the same is also attached for reference.
                    But i have some queries on this circuit
                    1. The resistors that burnt to crisp...
                    08-26-2020, 01:24 AM
                  • repair-it
                    Pioneer VSX-40 ,Trying to ID these resistors
                    by repair-it
                    I am trying to determine why these two resistors are the colors that they are. This is a Pioneer amp. The ones I am concerned about are the RED & GREEN colored resistors. I need to replace them and want to be sure to use the properly rated component....
                    12-16-2024, 02:08 PM
                  • BustinCaps
                    Dell 2007WFP resistors under white silicon blog
                    by BustinCaps
                    My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
                    04-29-2022, 06:19 PM
