I have a Macbook Air A1466 820-00165 that will not boot with the battery plugged in, it will boot of the charger but only when the battery is disconnected. With both the charger and the battery connected I get fan spin for about 5 seconds before it shuts off. When powered off the charger with the battery disconnected everything seems to work fine. It boots into the OS sees WiFi both keyboard and track pad work it also doesn't have a chime I believe but that's for later on. I have both the BoardView and schematics for this board. If I skipped any info or you need any more details please let me know.
Macbook Air A1466 820-00165 Won't Boot with battery installed.
Re: Macbook Air A1466 820-00165 Won't Boot with battery installed.
Try PRAM reset. If there's an EFI password set you'll have to remove it first.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
Did you try another battery?
What happens with battery only, no charger?
What's the voltage on PPBUS_G3H, PP3V42_G3H with battery and without battery?OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
PPBUS_G3H on battery 0.04v
PP3V42_G3H on battery 0v
PPBUS_G3H on charger 8.58v
PP3V42_G3H on charger 3.43v
PPBUS_G3H on battery+charger 8.58v
PP3V42_G3H on battery+charger 3.43v
It also looks like the battery did not get a charge overnight. Sorry if this info is useless I have very little experience working with macs
It looks like a dead battery to me, but first confirm the voltage on PPVBAT_G3H_CONN with battery only, charger disconnected.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView
