Macbook Air A1466 820-00165 Won't Boot with battery installed.
  • Psi
    • Feb 2019
    • 10
    • usa
    I have a Macbook Air A1466 820-00165 that will not boot with the battery plugged in, it will boot of the charger but only when the battery is disconnected. With both the charger and the battery connected I get fan spin for about 5 seconds before it shuts off. When powered off the charger with the battery disconnected everything seems to work fine. It boots into the OS sees WiFi both keyboard and track pad work it also doesn't have a chime I believe but that's for later on. I have both the BoardView and schematics for this board. If I skipped any info or you need any more details please let me know.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Air A1466 820-00165 Won't Boot with battery installed.
    Try PRAM reset. If there's an EFI password set you'll have to remove it first.
    • Psi
      • Feb 2019
      • 10
      • usa
      Just tried it, Got sound back so guess nothing is wrong with it but everything else remains the same.
      • piernov
        • Jan 2016
        • 4439
        • France
        Did you try another battery?
        What happens with battery only, no charger?
        What's the voltage on PPBUS_G3H, PP3V42_G3H with battery and without battery?
        • Psi
          • Feb 2019
          • 10
          • usa
          With just the battery only it does nothing. I have no access to a new/known good battery. I will check and post the voltages after I get back form work. And thank you for your help.
          • Psi
            • Feb 2019
            • 10
            • usa
            PPBUS_G3H on battery 0.04v
            PP3V42_G3H on battery 0v
            PPBUS_G3H on charger 8.58v
            PP3V42_G3H on charger 3.43v
            PPBUS_G3H on battery+charger 8.58v
            PP3V42_G3H on battery+charger 3.43v
            It also looks like the battery did not get a charge overnight. Sorry if this info is useless I have very little experience working with macs
            • piernov
              • Jan 2016
              • 4439
              • France
              It looks like a dead battery to me, but first confirm the voltage on PPVBAT_G3H_CONN with battery only, charger disconnected.
              • Psi
                • Feb 2019
                • 10
                • usa
                I'm getting 0v across PPVBAT_G3H_CONN
                • Psi
                  • Feb 2019
                  • 10
                  • usa
                  Tore the battery apart and the main IC on the charge board is corroded with 3 pins missing. Are ifixit batteries any good? Also Thank you very much for your input and time.
                  • twonk9098
                    Macbook Pro mid 2015 battery required to boot?
                    by twonk9098
                    I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                    The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                    This model has the newer trackpad which is not clickable when turned off.
                    At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                    If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                    12-10-2024, 06:51 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • trepachka
                    iPad Air A1475 Boot loops after replacing battery
                    by trepachka
                    This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                    The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                    I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                    11-08-2024, 03:17 PM
                  • Ancient1
                    MacBook Pro 2012 A1398 : Battery BMS circuit repair OR can it boot WITHOUT a battery ?
                    by Ancient1
                    Hi
                    I received such Laptop as junk. Opening it I saw a lot of whitish water residue , but no corrosion really ( few coils have small brown rust marks, no green copper ).
                    I cleaned all thoroughly and interestingly , its the Battery BMS board that has the real corrosion spots.. under the protective clear Goo !!
                    I want to try and power up the laptop
                    Battery is swollen. But I don't want to buy a new battery right now , of course .
                    I started work on the BMS by zooming in on green spots . 2 VIAs are filled with rusted copper goo - who knows...
                    04-17-2024, 12:46 AM
                  • code share
                    Lenovo P43s won't boot with internal battery connected – looking for help diagnosing battery issue
                    by code share
                    I'm having an issue with my Lenovo ThinkPad P43s. The laptop does not power on when the internal battery is connected, but it works fine on AC power alone (battery disconnected). Once the battery is reconnected, the system becomes completely unresponsive — no lights, no fan spin, nothing.
                    Here's what I've tried so far:
                    • Power/EC reset (held power button for 60 seconds with battery and AC disconnected)
                    • Booted successfully on AC power only with the battery disconnected
                    • Visual inspection of the battery — no swelling, burn marks, or connector damage
                    • Battery
                    04-21-2025, 12:50 PM
