What lab pwr. supply to get?
  • mosfetratus
    Sure Not
    • Feb 2019
    • 174
    • Resistron
    I have a board that have a short, not sure is where. So i need power supply to inject some voltage and see what is getting hot.
    So, do cheap aliexpress pwr supply will do the job? I'm not a professional, I fix my own laptop and friends if broke, not intensive.
    Ir i could make my own from ATX PSU?
    Would this do the job for 1V rail: aliexpress "PS1502"?
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: What lab pwr. supply to get?
    thats total crap
    IM VERY HAPPY with this little boy. its little but VERY usefull, great adjustable and it shows power consumption wich is TOP for laptop repair. i charge even autobattery with it. u just need a little fan and a 60W and more PSU. im using laptop charger
    https://www.aliexpress.com/item/DPS5...AbTest=ae803_3
    u can buy 5A version/DPS5005/ from 20euros or more powerfull up to 20A
    • piernov
      • Jan 2016
      • 4435
      • France
      15V 2A PSU won't cut it for laptop repair.
      I recommend at the very least 30V 5A
      With 30V you can at least go to 20V if you need to inject full voltage directly into power connector/B+ of laptop motherboard (don't do that randomly or you'll kill CPU/GPU, but sometimes it's useful).
      Also 2A is often not enough to detect a short. For example if you want to inject in a 1V rail that has a 0.2ohm short to ground, with a 2A it'll be 0.8W of power, not enough to catch anything heating up. With 5A this would be 5W, well enough to make something heat up.
      I'm also using some DPS buck converter.
      I have a DPS5015 with a "LED PSU" 50V 15A and a DPS8005 with a "LED PSU" 80V 5A.
      A real lab PSU has everything integrated into so it's a better in that regard but it's way more expansive for the same power.
      • Frenk7
        • Jan 2019
        • 25
        • Croatia
        I bought myself uni-t UTP3315TFL 30V 5A power supply and it is cheap (in my country about 90USD) and small, i think it is the best choice for us beginners
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3577
          • slovakia
          That DPS is totally awesome. with that watmeter i can tell exactly if laptop is totally not work or always rails is working or is shorted or athers states
          • mosfetratus
            Sure Not
            • Feb 2019
            • 174
            • Resistron
            Just ordered dp30v5al, same principle as DPS3005, but without fancy screen and some features. For half the price. Neat.
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3577
              • slovakia
              too bad for u
              u will be sure U WANT all that fancy screen and features when u try it.
              i try it and i NEVER want PSU without it
              • mosfetratus
                Sure Not
                • Feb 2019
                • 174
                • Resistron
                Just received it. Long time, but worth it. There is nothing similar to buy at this price of range in my country.
                This power supply is not bad. Very cute.
                Injected 1Volt to my x555ld motherboard, and heats up processors north bridge.
                Quality is good.
                Very like that 7segment display.
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  Yesterday, 07:14 AM
                • CMCM
                  Russound CA4 Power Supply Repair
                  by CMCM
                  Hello Everybody,
                  Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                  Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                  The outputs marked 12v and 20v are all measuring only 1v.
                  The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                  The capacitors physically look clean (no bludgesor leaks) and...
                  07-03-2025, 01:12 PM
