X453ma rev.2.0 pj8301
  • kalilinux25
    • Mar 2018
    • 2093
    • ZAMBOANGA SIBUGAY
    Ive check the pJ8301 and its shorted to ground
    But when I pump voltage on Pj8301 noting is getting hot and i cant i dentify what is getting short
    I already remove the coil
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3628
    • slovakia
    Re: X453ma rev.2.0 pj8301
    schematic please
    • on/off
      • Oct 2016
      • 333
      • Indonesia
      Boardview:
      https://www.badcaps.net/forum/showpo...0&postcount=14
      Repair guide:
      https://www.badcaps.net/forum/showpo...31&postcount=5
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3628
        • slovakia
        on what side is short after remove coil?
        • kalilinux25
          • Mar 2018
          • 2093
          • ZAMBOANGA SIBUGAY
          The positive sign
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3628
            • slovakia
            what voltage r u pumping in it?
            • dj_ricoh
              • 2073
              • uk
              If you make a trace go hot 10 amps?
              Lulz
              • kalilinux25
                • Mar 2018
                • 2093
                • ZAMBOANGA SIBUGAY
                Lulz
                yes yes
                • kalilinux25
                  • Mar 2018
                  • 2093
                  • ZAMBOANGA SIBUGAY
                  I cant open the bv ..
                  What software are you using?
                  • on/off
                    • Oct 2016
                    • 333
                    • Indonesia
                    Already many times mention it on this forum
                    • kalilinux25
                      • Mar 2018
                      • 2093
                      • ZAMBOANGA SIBUGAY
                      not functioning sir
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3628
                        • slovakia
                        http://laptopserviz.bg/enview/bvsoft/
                        • on/off
                          • Oct 2016
                          • 333
                          • Indonesia
                          Originally posted by kalilinux25
                          not functioning sir
                          I don`t have any issue with software on first link.
                          At first time maybe the boardviewer got error, just go to option on tab graphics choose GDI, That's it.
                          • kalilinux25
                            • Mar 2018
                            • 2093
                            • ZAMBOANGA SIBUGAY
                            thansk sir now its working som uch thanks
                            • jxrepman
                              Asus X453MA won't turn on and green led light blinking
                              by jxrepman
                              Hi there,
                              I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                              I have checked the charger and it is giving 19+ V
                              I have disconnected the battery and pressed power button for 30 seconds.
                              I tried another RAM stick.
                              Tried disconnecting the keyboard and touchpad.
                              Tried disconnecting the HDD and the wifi adapter.
                              The problem persists.
                              Hope you could help me out on this one. Thank you.
                              12-14-2024, 06:40 AM
                            • Christian0734
                              Asus X453MA Rev 2.0 Backlight and fan
                              by Christian0734
                              I brought an Asus X453MA into the workshop, its owner tells me that it doesn't work on battery despite having replaced it with a new one and that it's making noise. I diagnose and find, firstly, that the fan is constantly running at full speed. Secondly, that the computer works on battery but there's no backlight when the charger is not connected. I look at the screen connector because I see that the adhesive is not holding. I observe that there probably was a short circuit. I isolated everything with hot glue and reassembled it, I don't think it needs to be replaced. The BIOS is...
                              11-23-2023, 08:32 AM
                            • julianmustofa
                              Asus x453ma only turn on when plugged in (battery was fine)
                              by julianmustofa
                              Hi all
                              Iv'e been working on asus x453ma that only turn on when the ac adapter connected
                              The battery itself was fine
                              So this is what happen
                              -plugged ac adapter
                              -trigger power button
                              -laptop turning on
                              -unplug the ac adapter
                              Laptop still on with battery
                              -without ac adapter
                              And nothing happens
                              Have no idea what is going on
                              Charging sistem still works when laptop is turning on
                              And also when battery reach 100% the charging indicator still red. It should turn white/green...
                              10-18-2023, 01:48 PM
                            • Yosua
                              ASUS X453MA REV 2.0 +3VS didn't work
                              by Yosua
                              hi friends, I want to ask for help to solve my new problem on this ASUS X453MA REV 2.0 mobo, when I connect the charger the power light can turn on but the charging light is not on (battery condition is not installed) and the current shows remains at 0v, I've done flash bios but the case persists, and I've checked on all coils everything is okay, including the vcc coil, and after I search on the 3v&5v block alw it turns out +3VS doesn't show up it only shows 0.110mV in pq9108 on board view.
                              and my question is, where does this +3VS voltage come from?
                              I...
                              06-14-2022, 08:53 PM
                            • Yosua
                              Asus x453ma not charging
                              by Yosua
                              hello friends, I hope someone will give up a moment to help me solve the problem on the asu x453ma motherboard with the condition that it can't charge when it is charged, and this is the result of measuring the bq735 ic voltage
                              acin : 19v (pin1)
                              acdrv: 4.02v (pin4) unstable
                              sda: 2.5v(pin8)
                              regn: 6.2v(pin16)
                              vcc: 19v(pin20)
                              I hope someone can help me or give directions to solve this problem, thanks.
                              11-07-2021, 08:30 PM
