Gigabyte GV-R587UD-1GD graphic card repair
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3591
    • slovakia
    Hello.
    Have this Gigabyte GV-R587UD-1GD graphic card that not work and give a bad smell when in PC. i remove all main coils and have 0.3ohm on GPU side. no short on mosfets side. But when i inject 1V 5A to that 1.1ohm side the only thing that heats is GPU
    Do u thing that GPU is burned?
    Does anybody know what max voltage i can inject to this side?
  • dj_ricoh
    • 2073
    Re: Gigabyte GV-R587UD-1GD graphic card repair
    1v and under.
    There are gpu phase and.memory phase.
    Make a picture
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3591
      • slovakia
      short is on GPU phase but now i dont have PSU that gives more than 5A so i can give max 5W
      removed coils and caps to locate short
      • dj_ricoh
        • 2073
        Memory coil too.
        The ground it's the same.
        Memory goes to gpu. if gpu shorted memory too?
        I don't know this to.much but try to be sure.
        Ohm resistance after on gpu phase then memory.
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3591
          • slovakia
          i think i removed 4coils on GPU phase. where do u think is a memory phase?
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3591
            • slovakia
            did i must remove the ic to check if its really burned?
            • dj_ricoh
              • 2073
              What resistence you have on coil pads?
              Memory phase its on the other side of gpu.
              Less coils. Not the one behind.
              Holding the video card in front of you with pcie connector down on the left side of bag the coils are for memory(90%)
              Right side gpu phase.
              Check the ohms on all.
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3591
                • slovakia
                no short on that side. even on right side is one coil with two caps that is not on short/on picture still not removed/
                on gpu phase with removed coils and caps/on picture/ is resistance 1,3ohm
                right on GPU IC is no small caps on short, but found that 1,3ohm short on small caps on the other side of board under the GPU IC
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  0.3ohm, 1.1ohm, 1.3ohm? I'm confused.
                  1.3ohm sometimes is fine on a GPU. 0.3 is definitely a short.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3591
                    • slovakia
                    see my posts. 0.3 was mistake that i repair. on my posts only 1.3ohm
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3591
                      • slovakia
                      i was wrong about power of this card. it is even weaker that card i bought for 25euros
                      i dont care about it and remove GPU ic and short is gone
                      so i think the GPU was burn because all caps on it was without short
                      • dj_ricoh
                        • 2073
                        Ok now without bga start the card and measure all the coils and report back the voltage.
                        Off clean the pads and prepare the board if you receive a bga chip donor.
                        This the thing I will do in the near future. I have like 30 gpus like this.
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3591
                          • slovakia
                          it is not worth repair if its price is about 15euros, but i will post u voltages
                          • ktmmotocross
                            Boardkiller
                            • Feb 2014
                            • 3591
                            • slovakia
                            found great channel from guy who really show nice repair of graphic cards and prove that this ATI cards have mostly burned GPU, which is common problem on this cars
                            https://www.youtube.com/channel/UCLq...nHWIf6g/videos
                            • DynaxSC
                              GIGABYTE GA-H110M-S2 - Stuck at Debug Code C2 - don't like Patriot Viper Steel RAM but works with G.SKILL
                              by DynaxSC
                              I discovered a strange behaviour of GIGABYTE GA-H110M-S2 board.
                              General test conditions:
                              - Tested with Core i5 6500 and Core I7 6700K - no difference
                              - Default BIOS settings, but tried also altering several memory setting - does not change anything
                              What is wrong:
                              With BIOS F1 and F2 the board normally POST's and boots to Windows 11 with 2 x Patriot Viper Steel PVS416G440C9K RAM (4400MHZ, Samsung B-Die chips)
                              When BIOS upgraded to anything above F2 (ie. F20-F27b) the board POST stucks after 3 Debug Codes on Code C2
                              03-21-2025, 06:23 PM
                              Thermal pad thickness for various laptop GPU / Graphics Cards
                              ASUS Dual RTX 2070 OC 8GB
                              ASUS ROG STRIX RTX 3080 OC
                              ASUS ROG STRIX RTX 3090
                              ASUS TUF Gaming RTX 3080 OC Edition
                              ASUS TUF GTX 1660 S-O6G GAMING
                              EVGA RTX 3060 Ti XC GAMING 8GB
                              EVGA RTX 3060 XC GAMING 12GB GDDR6
                              EVGA RTX 3080 FTW3 ULTRA GAMING
                              EVGA RTX 3080 TI FTW3 ULTRA GAMING
                              EVGA RTX 3090 XC3 ULTRA GAMING 24GB
                              Gainward RTX 2080 Phoenix GS Specs
                              Gainward RTX 3070 Phoenix 8GB
                              Gainward RTX 3080 Ti Phoenix
                              GIGABYTE AORUS RTX 3080 MASTER 10G
                              02-09-2024, 08:08 AM
                            • flibidy
                              Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                              by flibidy
                              I have here a Magnum IA.100 which belongs to my parents.
                              The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                              Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                              What Ive done........
                              01-01-2025, 01:26 PM
                              A Dead/DOA Gigabyte GP-P450b 450W ATX PSU
                              by momaka
                              More eBay specials: this time a Gigabyte GP-P450b 450W ATX PSU for $8 with free S&H. Listed “For part/not working”, as usual. Showed up in a beat up EVGA box without any padding… but that's understandable given the total price. PSU made it out fine without damage. It's a non-modular (yay!), pretty modern-day looking PSU with a black paint and all black cables (meh, not my favorite, but figure it's good to keep a few of these in case I do need one for a more modern PC build, just so my old gray boxes don't look too odd in there.)
                              And a shot of the label:...
                              01-26-2022, 03:26 AM
                              Gigabyte Notebook Specification for Upgrade or Repair
                              This specification for the Gigabyte Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the boardview and schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Gigabyte Notebook is accurate, safe,...
                              09-07-2024, 07:19 AM
