Hp dv6000 daoat1mb8horev;h power issue, charging ok
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hello all, i just received this HP dv6000, after pressing power the system will want on and shutdown , i will see the fan and light want to turn on and shutdown, but is charging......Mother no DAOATIMB8HREV;H
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    Re: Hp dv6000 daoat1mb8horev;h power issue, charging ok
    check all big grey coils for short to ground. u can have shorted GPU
    • SuperJames
      Dell G3 17 3779 Weird power cycling and shutdown/restart issue
      by SuperJames
      This one's a weird one, and still unsolved despite it having gone back to Dell once.
      Specs
      i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
      Backstory
      I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
      10-23-2023, 04:09 PM
    • wagolla
      Request for Assistance: HP Laptop with LA-G07FP Motherboard Power and Charging Issue
      by wagolla
      HP laptop with the LA-G07FP motherboard has encountered persistent issues with powering on and charging. Here are the details:
      1. The laptop does not power on or charge consistently.
      2. When I remove and then reinsert the battery, the laptop will turn on when connected to the power adapter, and the battery charges normally.
      3. However, after approximately 1-2 days, the issue reoccurs, and the laptop will not power on or charge until I repeat the battery removal process.
      4. I have already updated the drivers and BIOS via the HP support website, but the problem persists.
      Could you assist with...
      10-28-2024, 12:14 AM
    • kalilinux25
      Power Issue, if shutdown it wont power on again.FH5AT LA-K092P REV 2.0
      by kalilinux25
      Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
      the laptop it wont power , it will shows led light for a second then shutdown.
      Tried clean Me bios smae issue
      tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
      ive check the motherboard for corrion but no avail
      Hope someone can guide which part of the board should I focus to narrow down the issue
      FH5AT LA-K092P REV 2...
      10-06-2023, 12:49 AM
    • justice171
      Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
      by justice171
      I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
      Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
      1. Verified that all critical voltages are present:
        • 3.3V and 5V are always present if DC is plugged.
        • 1.8V on the BIOS chip is present.
      2. Checked the power button functionality:
        • When pressed, the voltage drops to 0V, indicating the button is functional.
      3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
        • Confirmed connectivity is intact, ruling out issues
      11-26-2024, 12:39 AM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
