sony_mbx-229_wistron_cadiz- NO POWER
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3627
    • slovakia
    hello.
    have this sony_mbx-229_wistron_cadiz-cp_rev_-1m board with no power from main power mosfet.
    i measure that ACDET 2.6V signal is pulled down by AD_OFF_HW#
    from schematic i see that i need positive signal on pin 5 in Q68.
    But i dont find why it is not there. there are many ic U124,125,126
    and i see some mark on SIO Nuvoton which i think is a burn mark.
    Do u think that bad sio can be behind no ACDET signal?
  • mielta
    • Apr 2015
    • 368
    Re: sony_mbx-229_wistron_cadiz- NO POWER
    hi
    power it on with Battery ?
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3627
      • slovakia
      i charged battery with PSU to 12V but when i connected it i have only 3,3V on BAT ID and BAT IN# and 0,06V on BT+
      as i see the BAT IN# must be low to start battery and it comes from SIO, so that burn mark on SIO can be my main problem
      do u think i can check other thinks by pulling down BAT IN# and start battery or i missed some signal that telling sio that battery is connected and charged?
      • on/off
        • Oct 2016
        • 333
        • Indonesia
        Originally posted by ktmmotocross
        hello.
        IMO
        Maybe that things have related with other voltage rails or 3V/5V rails.
        Sony vaio protection always make headache
        AFAIK
        I think AD_OFF_HW# issue cause SYS_PRS and U125 output need logic H, Check your RTC_BAT.
        Also the enable bat i think SYS_PRS#_1 need 0V.
        (already prove by your TIP thread, one cable connect to pin 7, right bro?)
        • mielta
          • Apr 2015
          • 368
          Check with an psu Bench
          give 19v on r2492 an how is amp
          Ithink Sio is defect Check if VCC or Vdd shorted
          • ktmmotocross
            Boardkiller
            • Feb 2014
            • 3627
            • slovakia
            i think this was a mistake
            found shorted both highside mosfets on 3,3 and 5V lines
            when i inject 3V to 3,3V line PCH start to heat up real quick and draw more than 2,5A
            5V line looks good, it draw about 1A and it lowering when i desolder chips connected to it
            if all ic connected to 3,3V and 5V lines got hit from 19V, dont think it is refundable repair.
            but i save this laptop to time when i have another PCH to replace it
