lenovo g50-45 charger not dictect
  • akande
    • Dec 2017
    • 278
    • Nigeria
    i hav lenovo g5045 which doesnt charge when plug in adapter pc cannot power , but work fine with charged battery.
    Little check done no luck---- pPU4 vin0v,adect 0v , acok 5v,vcc 19v, i change PU4 NO LUCK . i need assistance plz
  • Techtiger
    • Oct 2014
    • 1602
    • france
    Re: lenovo g50-45 charger not dictect
    check Voltage
    PQ6 pin (5.6.7.8) (4) (1.2.3) after with out all power test with multimeter diode mode Source Drain Gate
    PQ7 pin (1.2.3) (4) (5.6.7.8) after with out all power test with multimeter diode mode Source Drain Gate
    check Voltage PQ30B pin 5 and 3
    check Voltage PQ29B pin 5 and 3
    remove the jumper PJ2 test restence to GND bouth sides of the Jumper
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
    • Mita99
      Lenovo Thinkpad P72 EP720 NM-B723 MB - Power disabled within 2 seconds after plugging the charger
      by Mita99
      Try to repair a Thinkpad P72 EP720 NM-B723 MB with I7-8850H processor and N18E-Q1-KB-A1 (P3200) GPU with 6GB memory. Unfortunately there is noinfo what happened to the laptop. I got it disassembled with parts missing, like keyboard, battery.
      Unfortunately I have no schematic available for me (requested in the sub porum) but got the boardview file.
      Symptom: after connecting to the charger the power led light up for one-two second and switch off. After a couple secons the power led light up for half a second and switch off. No battery, no IO board, no...
      04-27-2025, 07:20 PM
    • totto210
      lenovo legion 5 15-lmh05 nm-c911 charger problems
      by totto210
      Hi guys, well the summary is this:
      the equipment arrived because it did not turn on (it had been the original 230w source the problem) then I feed with my regulated source and without wanting to invert the poles. the equipment turned on and turned off.
      This damaged the charger and its mosfets both high and low switching.
      It also damaged the input mosfet (pq102).
      by chance i had another lenovo legion just like this one and i removed the components and tried to turn it on and it turned on but ....... it burned again the high and low mosfets and switch (pq104, pq105, pq103)....
      05-23-2024, 10:03 AM
      Lenovo 3000 Series Schematic
      Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
      3000 C100 laptop with Braille keyboard
      Lenovo 3000 C
      C100, C200 - 15-inch XGA screen
      Lenovo 3000 N
      N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
      N500 - 15.4 inch screen.
      Lenovo 3000 V
      V100, V200 - 12.1-inch WXGA models
      Lenovo 3000 G
      G400, G410, G430, G450, G455, G510, G530, G550, and G560...
      10-04-2024, 06:05 AM
