Acer 5315 LA-3551P
  • Prosatanosz
    • Nov 2015
    • 108
    • Hungary
    Acer 5315 LA-3551P
    Hi. Dev cant be switched on with soldered cmos battery. Widthout battery or empty battery working well. Any idea?
    • 21936
    Re: Acer 5315 LA-3551P
    Check CMOS battery voltage, if too low replace it.If its ok check the RTC area on the schematic .
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Check schematic, find the switching pin on kbc. Put a 3V cmos battery and try directly shorting the switching pin on sio to gnd and see if it turns on.
      • questore
        XPS 13 9370 CMOS battery voltage always low
        by questore
        Hi Everyone,
        I have brought you a mistery item
        This laptop have come with some strange faults.
        1. CMOS battery was flat 0v
        Symptoms:
        - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
        Amp drawing was stuck at 0.005 milliamps.
        - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
        After inverstigation RTCD1 diode had a low value...
        09-30-2025, 05:47 AM
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • DenK
        Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
        by DenK
        Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
        1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
        12-06-2024, 01:29 AM
      • survivalbloke
        Acer Predator Helios 300 - will not power up if battery is CONNECTED
        by survivalbloke
        This was a no power initially. Thanks to your help, I discovered it was the first mosfet, so I replaced. Now, the device will power up only if the battery is NOT connected. As soon as I connect the battery, it shuts off. If I connected the battery while the device is off, it simply will not respond to the power button. I replaced the battery, and while I suppose the new battery could be faulty, I'm assuming it is not. I'm having the same behavior with the new battery. I measure .2v at the charging coil. Manually applying power to the + and - at the battery header, there is no charging happening....
        06-25-2025, 12:20 PM
      • ahmarzo
        Acer TMX314-51 laptop battery problem
        by ahmarzo
        I have acer laptop tmx314-51 with part no 6050A3020501.
        The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
        But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
        I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
        The schematic is not available...
        04-11-2025, 09:14 AM
