Dell Laptop Dead.
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Dell Laptop Dead.
    SO I have a dead dell laptop that does not turn on. I also do not see any shorting when using DC power supply.
    The board does have 3 /5 ALways voltage . there is not voltage on PIN 8 of the Bios Chip though.
    Also I am attaching a pic and would like to know why I am getting 0 voltage on the other end of the resistor
  • IamPritesh
    • Aug 2017
    • 356
    • India
    Re: Dell Laptop Dead.
    Anybody please help
    • Techtiger
      • Oct 2014
      • 1602
      • france
      for me it's normal PQ903 N Channel Mosfet gate Voltage 5V S & D GND
      +B 19V with Voltage Dividers 20K &100K 3.64V OK to PQ903 Gate pass to conduct 19V to B+BIAS
      send the Schmatic to find out adsent of 3.3V in bios leg 8
      • IamPritesh
        • Aug 2017
        • 356
        • India
        Thanks. After giving some heat on the SIO Chip now the laptop starts but has no display and no post.( Schematic attached )
        Even after removing the Ram , there is no beep . The fan spins and two LEDS glow. The PCH also slightly warm.
        Where should I start now ? Any checkpoints please..
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Check voltages on Vcore coils and Ram. Might be bios issue
          • Techtiger
            • Oct 2014
            • 1602
            • france
            test all gray coils for voltage
            PL700 +VCCGFXCORE
            PL701 VCCCORE
            PL900+VGA CORE
            PL600
            PJP300 JUMBER +0.75VS
            PJP303 JUMPER +1.5
            ect save your old bios and try to flash bios you have 2bios chips i think you have to flash PCH one
            • IamPritesh
              • Aug 2017
              • 356
              • India
              PL700 +VCCGFXCORE - No Volts
              PL701 VCCCORE - No volts
              PL900+VGA CORE - 0.14 Volts
              PL600 - 0 volts
              PJP300 JUMBER +0.75VS - 0.74 Volts
              PJP303 JUMPER +1.5 - 1.48 Volts
              • IamPritesh
                • Aug 2017
                • 356
                • India
                Any help friends ?
                • Techtiger
                  • Oct 2014
                  • 1602
                  • france
                  test voltage pin 22 ISL95833 +5VS
                  PQ700 +B
                  PQ701 +B
                  test 5 mosfets for any short
                  PU600 PIN 12 +VALW
                  MOST PROB BIOS ISSU TRY TO FLASH BIOS
                  • max-power
                    Dell E6540 laptop completely dead after dssasembly
                    by max-power
                    Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
                    that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
                    After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
                    03-24-2025, 08:49 AM
                  • Loli Popu
                    DELL 5590 LAPTOP DEAD AFTER BIOS WRONG FLASHED
                    by Loli Popu
                    Hello guys ,i have a dell latitude 5590 with f411p bios,this laptop has bios password ,i tried to read the bios(winbond 25q128jv) with ch341 but when goes to verify give error ,it said doesnt match .After this i flashed another bios which is cleaned and then the laptop was dead ,i tried to turn on but only white light in the buton power turned on several times and then no display at all .I had a backup and flashed again the original bios ,but this time the laptop will not turn on at all ,no light nothing,the bios original bios that i flashed was having verify error when i verified with ch341 ,i...
                    12-13-2024, 03:28 AM
                  • Vampy_1110
                    Modifying output voltage of an Old Dell laptop charger
                    by Vampy_1110
                    I'm trying to turn this old dell laptop psu into a variable power supply (5-19.5) as i have already modified a few power supplies before and now i want to do the same with this but it's a bit complicated
                    The pic below has an op-amp ic (Z103WA) that does the CC/CV adjustments and a double diode 3 pin ic at the far right
                    As you can see there's no TL431 or Switching ic self-regulations that i can tweak easily.
                    Any help would be appreciated
                    02-12-2024, 03:17 PM
                  • tvguy12012012120
                    by tvguy12012012120
                    02-07-2025, 05:13 PM
                  • Mots06
                    Old Dell E5400 Laptop ( Purchased in the year 2008)
                    by Mots06
                    Hi, I'm unable to find the motherboard number (PPID number) or the board view for this old laptop. My laptop won't start, and when I enter the serial number on the Dell website, it says the number is invalid. The sticker on the bottom is unreadable because it has faded over time. Unfortunately, I'm unable to start the laptop to use the power cell or explore other options.I needed the CMOS Cell & it also seems the Laptop will not start now because of the power switch issue, which is yet to be detected.
                    07-19-2025, 01:56 AM
