Lenovo 500-15isk LA-C851P without CPU voltage
  • kokono
    • Jun 2018
    • 203
    Lenovo 500-15isk
    LA-C851P
    i measured all voltage, only cpu dont work
    there is NCP81208 chip for three rail voltage :
    VCC_core VCC_GT and VCC_sa
    only one of three voltage working .ist 1volt
    two voltage ist null . i replaced 81208 chip ,but dont change. also i chnaged two NCP81253 together, one have voltage another ist null. also dont change
    So i think 81208 and 81253 not defect and problem ist another place.
    i can see three pin Communication (SOC_SVID_CLK ,SOC_SVID_DAT,SOC_SVID_ALERT) that connected direct to cpu .
    any person have idea for my problem ?
    How one of three voltage rail working , because all enable pin ist same but with seperate PWM ?
    i dont found datasheet for 81208 but i thinks ist similar NCP81243
  • fauzanmint
    • Jun 2018
    • 82
    • Indonesia
    Re: Lenovo without CPU voltage
    Chek all your pgood pins
    • kokono
      • Jun 2018
      • 203
      i checked
      i am sure that +VCC_SA(one of three Rail voltage for NCP81208) ist ok ,plus VR_PWRGD
      Also i think +VCCIO is good.
      Have an idea?
      i reprogram Bios with this file.maybe my problem ist Bios ???
      please check my bios
      • kokono
        • Jun 2018
        • 203
        No one can help?
          • 21907
          I got your PM. Try this bios.If it doesn`t work keep testing .
          • RJARRRPCGP
            • Jul 2004
            • 6304
            Looks a lot like 2015! So an absurdly short life before a failure!
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • kokono
              • Jun 2018
              • 203
              thx for reply
              i reprogram, now i have VCC_core(1 Volt clear) without VCC_GT.
              i think my problem ist Bios
              in addition, my Bios chip isn't 25Q64 . ist 25Q064A13. maybe ist important
              • kokono
                • Jun 2018
                • 203
                Do you can modifying my bios program ?
                with your Bios ,VCC_Core working only VCC_GT dont worked
                i am sure that dont have hardware problem
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  VCC_GT here refers to GFX Core ?? If so , it can be missing coz of many reasons like Bad bios, Bad ram stick or slot, PCH, Vcore ic(i rule it out as you have already replaced it) and missing DRAMRST# signal.
                  I'll suggest to check DRAMRST# signal on pin30 of Ram Slot. It should be 1.3V approx.
                  • kokono
                    • Jun 2018
                    • 203
                    VCC_GT here refers to GFX Core ??.
                    i thinks No, because i have GFX voltage
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      ok. I didnt looked at the diagram. Just thought of it. Thanks for correcting.
                      • kokono
                        • Jun 2018
                        • 203
                        Update :
                        today i checked again, i can see when press start button,The LCD turns on and gets darker but without backlight
                        can i connect "VCC_Core" Enable pin to "VCC_GT" Enable ?
                        • Pferd5
                          • Mar 2018
                          • 72
                          did you solve the issue?
                          • kokono
                            • Jun 2018
                            • 203
                            Yes,After reprogram Bios,and without VCC_GT, i changed a lcd cable and working
                            • RotVik
                              Learning...
                              • Feb 2016
                              • 57
                              • Mexico
                              If I am getting it correctly a bad LVDS cable was causing VCCGT to be missing?
                              • piernov
                                • Jan 2016
                                • 4439
                                • France
                                https://logi.wiki/index.php/User:Pie..._I_solve_it.3F
                                • rddube
                                  Lenovo L490 Ram voltage circuit malfunction
                                  by rddube
                                  Hello friends,
                                  Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                  I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                  07-15-2025, 04:41 PM
                                • erico
                                  Lenovo X1 Carbon BIOS not getting voltage
                                  by erico
                                  First of all, ive veen reading these forums for some time and its always veen very helpful, so i thank you all for this amazing comunity.
                                  I have a lmq-2 13268-1 motherboard from a lenovo x1 carbon 3rd gen. And the MX25l12873f (U49) bios pin 8 is not getting voltage.
                                  So far these are my diagnostics:
                                  When given 19v trough power adapter, consumption reads 0.003 amps for about 5 seconds then nothing.
                                  When power button pressed same result, and i get three green blinking lights from the pwr btn led. But foesnt turn on.
                                  If i plug the battery...
                                  05-02-2024, 02:40 AM
                                • jaroslav.psenicka
                                  Lenovo Yoga 13 Panasonic, no video, fan OK, missing voltage rail (?)
                                  by jaroslav.psenicka
                                  I have a Lenovo Yoga 13 Panasonic here, when powered
                                  • both fans spins (the sconds starts with a bit of a delay), no image neither on HDMI nor the display
                                  • most voltage rails seem OK (see image below, red labels)
                                  • resistnace to ground mostly seem OK as well (blue labels)
                                  the only suspicious is the 0.0V rail (2nd from left, top row)
                                  • the resistance to ground is rather low (1.9ohm)
                                  • when injecting the voltage (1V), it consumes around 200mA, seems OK to me (?)
                                  also tried new BIOS, no change
                                  I can't find a schematics for the board - can some of you gurus look at the voltages?...
                                  05-02-2024, 05:59 AM
                                • wrobbie
                                  Lenovo T14 (AMD, gen1) over-voltage protection IC keeps dying.
                                  by wrobbie
                                  My T14's (NM-C801) main USBC input keeps failing every few months. Initially, it worked fine for several years. The symptom is that once powered from the main USBC port using a 65W power brick, after some time (minutes, hours) charging will fail completely. Powering from the secondary (docking) USBC input still works. This laptop is basically always plugged in. The first time it happened, it took me a long time to find that the FPF2281 over-voltage IC for that USBC input was at fault. When the issue occurs, it will continuously reset power delivery negotiations with the power brick -- according...
                                  02-26-2025, 10:02 PM
                                  Lenovo 3000 Series Schematic
                                  Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
                                  3000 C100 laptop with Braille keyboard
                                  Lenovo 3000 C
                                  C100, C200 - 15-inch XGA screen
                                  Lenovo 3000 N
                                  N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
                                  N500 - 15.4 inch screen.
                                  Lenovo 3000 V
                                  V100, V200 - 12.1-inch WXGA models
                                  Lenovo 3000 G
                                  G400, G410, G430, G450, G455, G510, G530, G550, and G560...
                                  10-04-2024, 06:05 AM
