Need help troubleshooting a faulty motherboard (Lenovo U41-70)
  • ghostiee
    • Nov 2018
    • India
    I've been a technican for many years but I can only troubleshoot to the major parts, and I know nuts about component-level such as capacitors, resistors, ic chips, soldering etc.
    My own laptop's motherboard failed - no power no response at all. AC adaper is working fine.
    I just bought a multimeter and checked the piece of AC charger port cable that's connected to the motherboard.
    After connecting the AC adapter and turning on the power, I measured 20V on the following combinations:
    PIN 1 & 4
    PIN 1 & 5
    PIN 2 & 4
    PIN 2 & 5
    I assume PIN 1 and 2 are + while PIN 4 and 5 are ground. This cable is OK.
    I connect the cable to the motherboard and measure the connectors to the motherboard. As pointed out by the red and orange arrows, I am NOT ABLE to get 20V. When measuring PIN 1 or PIN 2 with ground, I am only able get a reading of 0.x to 1.0 V.
    What is the issue?
    Additionally, I notice one IC that seems to have "burst". "7401" and "GA5T1A" are printed on the chip but I tried many search engines and parts/components database, I just can't find anything relevant.
    This burst chip is very small and very near to the power connector on the motherboard. If you refer to the second photo, you can find reference of the burst chip relative to the power collector by looking at the location of "PJ511K" chip on both photos.
    In the second photo, you can also see how small is the burst chip relative to my thumb.
    Any help will be appreciated!!!!
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5044
    • US
    Re: Need help troubleshooting a faulty motherboard (Lenovo U41-70)
    you posted this on like 3 different forums. It's probably a MOS chip but it looks like just flux, not 'burst', still could be bad though.
    sometimes I miss my admin power to move this to the laptop forum
      • 21968
      Agreed,this should be in the laptop forum.
      What is the part number on the mobo ,it may start with LA- .The white part at the end of your finger on the 2nd picture is a fuse. Desolder that to start with and test it . The "burst" chip is a Alpha Omega AO7401 https://cdn.badcaps-static.com/pdfs/...05b74370b3.pdf
        • 31259
        what's the resistance between the tab and pins on that part?
        • Krisdf
          • Dec 2018
          • Danmark
          Hi!
          Sorry to be posting here since it's in the wrong category, but I have the exact same laptop with the same symptoms described by OP.
          Looking at the MOS chips in question I can confirm mine also looks flux/bust
          When the laptop is plugged to A/C a "clicking" sound begins to emerge becoming louder the longer its plugged in (though its still faint even when loudest)
          The chip depicted by OP also becomes very hot! Like to hot to touch. Of course this may be by design though....
          Op have you gotten closer to a resolution?
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • nrj1982
            Lenovo Ideapad3 NM-C821 faulty motherboard
            by nrj1982
            Hello all,
            I have a Lenovo Ideapad3 laptop, that has recently stopped working. When pressing the power button, the led is going on, but nothing else is happening.
            I have checked the 3.3V, 5V and 20V - all of them seem present (checked with multimeter and oscilloscope in order to verify that they are stable).
            I have checked the voltages around PU1901 - 0.9V, 1.8V, 5V, 2.5v, 0.6V and 1.2V - all of them are present.
            Now going further in the debug, I found that the CPU voltages produced by RT3662AC (PU5901) PWM driver are missing. I can see that the 20V...
            10-04-2025, 10:08 AM
          • andrhouseolly
            Lenovo X240 - motherboard replacement for X250, no image.
            by andrhouseolly
            Friends. I beg you to help me in this situation.
            Lenovo X240 with a video problem. Native Intel drivers are not installed,
            after installation, a black screen. It works with the standard Microsoft driver.
            Understanding that there are problems with the video core,
            I ordered a motherboard from Lenovo X250.
            The laptop turns on, starts up, there is no image on the internal display.
            The image is output to the external monitor.
            I ordered another motherboard from Lenovo X250.
            07-12-2024, 03:02 PM
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • mkdj
            MacBook Air A2337 (820-02016) - 5V, won't turn on - please help me understand why
            by mkdj
            About me, my goal and the equipment I (don't) have:
            I am brand new to this forum, and I am eager to learn about repairing laptops. I have an engineer background although I haven't done electronics for a while. I have watched several Youtube videos in the last two months, trying to understand how to diagnose a faulty motherboard. I have a USB-C Amp meter and a classic multi meter. No DC Power Supply to inject voltage, no soldering iron to replace components.
            About my issue and my goal:
            A friend of mine has a MacBook Air M1 A2337 that does not...
            04-03-2025, 08:28 AM
