Asus X555LD Rev. 3.1 no power
  • Conste
    • Oct 2018
    • 235
    Hey there,
    I have a problem with a defective laptop I recently purchased.
    Asus F555L, board X555LD Rev. 3.1.
    The laptop is dead, no power on is possible, battery is not charging, no LEDs.
    19v are there, also 5v and 3.3v, but only at some points, not on the bios chip. Main power generator is getting warm..so I think it could be short somewhere.
    Can you give me any advice of how to fix it?
    Thanks in advance.
    Constantin
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: Asus X555LD Rev. 3.1 no power
    Check and report voltage on battery connector and check +3VA_EC
    • Conste
      • Oct 2018
      • 235
      +3VA_EC is at 0,06v - so nothing.
      Battery is
      0v
      0v
      0v
      0,275v
      0,06v
      0,06v
      2,6v
      2,6v
      All measured with reference to ground.
      Thanks.
      • caspian
        • Oct 2015
        • 1590
        • Laptop
        Now measure +3VAO on PSL8101.
        • Conste
          • Oct 2018
          • 235
          3,226v - I guess U8100 is the central power supply for 5 and 3,3 ?
          • caspian
            • Oct 2015
            • 1590
            • Laptop
            that is right for PU8100.
            Now measure voltage on both sides of PR9100 and PSL9101.
            • Conste
              • Oct 2018
              • 235
              PR9100 on both sides 3,2v
              PSL9101 0,06v
              • caspian
                • Oct 2015
                • 1590
                • Laptop
                thus it seems PU9100 needs to be replaced.
                • Conste
                  • Oct 2018
                  • 235
                  okay, is there any way to Bridge the part?
                  I tried to Bridge it, took the 3,3v and put it to +3VA_EC, but no signs of life...but the power consumption Drops from 2,5W to 1W..
                  • caspian
                    • Oct 2015
                    • 1590
                    • Laptop
                    Diese bridging ist keine gute idee. If you want to bridge it, you have to think about lots of things first.
                    how much voltage on pin4 of PU9100 ?
                    • Conste
                      • Oct 2018
                      • 235
                      PIN 4 should be 3,207v.
                      PIN4 goes to the power button according to boardview, am I Right?
                      Can u give me a recomendation for a hot air Station, just shouldn't be too expensive.
                      WIll be my first hot air action
                      • caspian
                        • Oct 2015
                        • 1590
                        • Laptop
                        If pin4 is 3v or more before pressing the power button, replace PU9100.
                        If you find an old model of QUICK rework stations in your city, it should be cheap but powerful. I use QUICK700. It worth finding a used one of QUICK700.
                        https://www.amazon.in/Quick-700-Rewo.../dp/B00P8RF7GW
                        • Conste
                          • Oct 2018
                          • 235
                          okay, I will order some parts
                          What About a QUICK 857DW+? It is less than 100€ here in Germany
                          Or a quick 2008?
                          • caspian
                            • Oct 2015
                            • 1590
                            • Laptop
                            QUICK 857DW+ seems to have a max temperature of 100'C. it is too low.
                            quick 2008 seems to be digital. So I do not recommend it.
                            • Conste
                              • Oct 2018
                              • 235
                              both of them are digital, DW857+ is adjustable from 100 - 450°C, but has a Pretty low power consumption.
                              2008 has more power and can be adjusted from 100 - 500 °C, why don't u recommend it?
                              • Conste
                                • Oct 2018
                                • 235
                                Hello again,
                                I ordered the Quick 2008. I will come back to the laptop when the parts arrive.
                                Thanks for the advices
                                • caspian
                                  • Oct 2015
                                  • 1590
                                  • Laptop
                                  it is possible that some other component is damaged in addition to PU9100. So, it is possible that you need to fix some other component after replacing PU9100. But it is also possible that only PU9100 be the problem and the laptop gets fixed after replacing PU9100.
                                  For rework station, search this forum. there are some threads that recommend what rework stations to use.
                                  • Conste
                                    • Oct 2018
                                    • 235
                                    Yes, we will see.
                                    Is it possible to desolder PU9100 and then put power on to board to measure the power consumption or to check if power supply is still getting hot? Or would this destroy something?
                                    • caspian
                                      • Oct 2015
                                      • 1590
                                      • Laptop
                                      it is not required to do this test.
                                      • Conste
                                        • Oct 2018
                                        • 235
                                        I managed to desolder the part - the power IC doesn't get warm anymore, so there could really have been a short in PU9100.
                                        I will report when I soldered the new IC inside.
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • ShadowAi
                                          ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                          by ShadowAi
                                          Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                          Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                          After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                          03-15-2024, 10:46 AM
                                        • meraklinetx
                                          Asus Z97-a power cycle, no boot no cpu voltage
                                          by meraklinetx
                                          Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                          05-10-2023, 06:08 AM
