Asus X555LD Rev. 3.1 no power
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Asus X555LD Rev. 3.1 no power
    now check whether any pad located under PU9100 is shorted or not.
    • Conste
      • Oct 2018
      • 235
      How do you mean?
      If the solder points are directly shorted? This is not the case.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        If there is no shorted pad, then it is ok to solder the new IC.
        • Conste
          • Oct 2018
          • 235
          Managed to buy a defective board from eBay. Board is okay, but no video on internal screen, but on HDMI. With this board I can test all the voltages and maybe find the fault of my board.
          Regards,
          Constantin
          • Conste
            • Oct 2018
            • 235
            The defective board arrived yesterday and works expect of the internal screen. I measured some voltages and found out, that the screen isn't recognized by the board at all...webcam works btw.
            I also found out, that Panel VCC of J4502 is not available
            +3VS is there and also AC BAT SYS
            What shall I do to revive the board?
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              #26
              first measure voltage on both sides of R4512.
              • Conste
                • Oct 2018
                • 235
                Hello caspian,
                Thanks for ur help in Advance!
                Voltage on both sides is 0v, but the board is Rev. 2.0 and not 3.1 - when I look at the boardview of Rev. 3.1, there are two resistors in this area, on my board are only two of them.
                Regards,
                Constantin
                • caspian
                  • Oct 2015
                  • 1591
                  • Laptop
                  #28
                  If it is rev2, measure voltage on both sides of R4513.
                  • Conste
                    • Oct 2018
                    • 235
                    Hello caspian, could you please send me the boardview of rev. 2, please?
                    • caspian
                      • Oct 2015
                      • 1591
                      • Laptop
                      #30
                      here it is:
                      • Conste
                        • Oct 2018
                        • 235
                        Hello caspian,
                        0v on both sides - does that mean that U4501 is bad?
                        Rrgards
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          #32
                          U4501 is the main suspect now. but you cannot be sure unless you mention voltage on all pins of it. take a lot of care not to shorten it's pins when measuring. Es ist wirklich riskant zu messen.
                          • Conste
                            • Oct 2018
                            • 235
                            I tried to measure the Pins of U4501.
                            1 1,204V
                            2 1,164V
                            3 1,178V
                            4 3,268V
                            5 1,202V
                            6 0V
                            7 3,246V
                            8 3,261V
                            9 0V
                            10 0,04V
                            11 0,04V
                            12 0,04V
                            13 0,041V
                            14 0,04V
                            15 0,04V
                            16 3,26V
                            17 0,047V
                            18 0,048V
                            19 3,261V
                            20 0V
                            21 0,0047V
                            22 3,26V
                            23 3,24V
                            24 3,238V
                            25 1,202V
                            26 0V
                            27 0V
                            28 0,540V
                            29 0,540V
                            30 0,546V
                            31 0,548V
                            32 0,0014V
                            33 0,84V
                            34 0,84V
                            35 3,26V
                            36 1,206V
                            Thanks in Advance and have a nice evening!
                            • caspian
                              • Oct 2015
                              • 1591
                              • Laptop
                              #34
                              If the laptop shows picture on the VGA and the HDMI ports, then U4501 is probably faulty. In another case, it is also possible that the CPU or GPU be faulty. Is there any GPU on the mainboard?
                              finding the datasheet of ANX1121 would help, but it seems it is not available. I found just a single page datasheet for it which is not useful to us.
                              • on/off
                                • Oct 2016
                                • 333
                                • Indonesia
                                #35
                                ANX3111-ANX3112 pin out
                                • Conste
                                  • Oct 2018
                                  • 235
                                  Okay
                                  GPU is an NVIDIA GeForce 820m
                                  Maybe tomorrow I will manage to solder the N Channel mosfet to the other board, to make it power up again. Maybe then the laptop works again.
                                  • Conste
                                    • Oct 2018
                                    • 235
                                    I tried to solder the part, but I think I didn't suceed, no voltage after the part. Maybe the soldering is bad - can you tell me a good flux?
                                    We also found out that on the board which powers up we has around 6v on PIN 12 of PU 9100. In the datasheet this pin is called SS1 (soft start 1). Does the IC get a voltage from here or does it produce this voltage by itself?
                                    If the voltage Comes from outside, the Problem is another one.
                                    Thanks in Advance!
                                    • caspian
                                      • Oct 2015
                                      • 1591
                                      • Laptop
                                      #38
                                      pin SS1 does not come from outside.
                                      • Conste
                                        • Oct 2018
                                        • 235
                                        Well, then the soldering job was shit. The solder didn‘t even melt, so I guess that is the problem.
                                        Tomorrow I try to take the solderiron down and put new one on the pads.
                                        I also ordered solderpaste, if this doesn‘t work.
                                        Thanks again caspian
                                        • caspian
                                          • Oct 2015
                                          • 1591
                                          • Laptop
                                          #40
                                          first practice soldering of a similar IC on a useless scrap board. then, when you learned the skills, try on the board which you are repairing.
                                          • GLISIT
                                            by GLISIT
                                            01-16-2025, 02:29 PM
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • PantherDave
                                            by PantherDave
                                            Hi all!
                                            05-29-2024, 02:01 PM
                                          • ShadowAi
                                            ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                                            by ShadowAi
                                            Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                                            Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                                            After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                                            03-15-2024, 10:46 AM
                                          • meraklinetx
                                            Asus Z97-a power cycle, no boot no cpu voltage
                                            by meraklinetx
                                            Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                                            05-10-2023, 06:08 AM
