Acer E5-571G Black Screen (a5wah la-b991p)
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Acer E5-571G Black Screen (a5wah la-b991p)
    I faced this issue on dell 3537 and couldnt fix it. May be SOC fault but not sure.
    • comifrancesco_f
      • Oct 2021
      • 9
      • Italy
      Originally posted by Sametbey
      can you try? " Acer E5-571G A5WAH LA-B991P Rev 1.0
      When the solder on the PJ1002 jumper feeding the RAMs on the left side of the GPU is cleaned and the U40 mosfet located on the right side of the GPU is removed, the Nvidia graphics card is disabled. "
      Thanks, worked for me, also shift the resistor rp16 and flashed the rom.
      • renxander
        • Aug 2017
        • philippines
        can you upload the rom?
        • Ryan.man
          by Ryan.man
          02-04-2025, 12:23 PM
        • smic717394
          by smic717394
          07-25-2024, 10:16 AM
        • Chrissygizmo
          by Chrissygizmo
          02-10-2025, 12:33 AM
        • spice_disc
          Vizio TV M50-C1 reboot cycle and static on screen
          by spice_disc
          I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
          The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
          09-08-2024, 02:37 PM
        • ipatch
          ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
          by ipatch
          i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
          08-24-2024, 02:36 PM
