After repair now boot from USB drive HP-4730s
  • pecrie
    • Nov 2011
    • 182
    Ok so I got familiar with the Bios options of this laptop.And after some hours of getting a bootabl USB drive , I finally got to the Rufus site and created a bootable USB drive.
    The MSoft DVD tool is not working (giving the well known error when chosen for the Winxx ISO file.
    After a long time I figured out that the UEFI boot is different.Yes , the USB drive is formatted in FAT32.
    So in the boot menu you choose the boot system - your usb drive.
    Then in the new drop down menu >UEFI boot > underneath there are 2 buttons.The top button has 1 dot and the 2nd button has 2 dots in it.
    Obviously , this corresponds to the DOS system - where 1 dot means that you are in the root menu/folder.
    While 2 dots means you are in the subfolder.
    Click on the 1 dot > UEFI menu > boot > then you will see some buttons with different tekst /symbols
    Go to the button with (I believe) EFI_x64 .As I had Win7 64 bit on the USB drive.Click on EFI_x64 and it started to download the windows files.
    After the 1st reboot I pulled the USB out of the laptop.It the continued to install from the hard disk.
    Then came the part to install Win 7 on the HDD partiton.
    I created a install partition (and the system created additional partitons like the MBR and the other partition - they are just some MBs big).
    Now after formatting the partition it was a Primary partition.But then I got the message that Windows could not be installed on that partiton , because there may not be the correct drivers for the hardware !!!!!!
    Okay , so I browsed for a folder where maybe the correct drivers were.I believe that I noticed that UEFI also had some sort of windows install folder.
    Anyways I let it search in the boot folder and then in the support folder.Tried again to install on the Prim partition.Again the same message.
    I browesed again now on the USB drive in the Win 7 ISO folder > in the boot folder and then in the support folder.
    Got back again to install on Prim Part - no go ......
    I choose the partiton and did another Format , and then hit NEXT again , and guess what , it started the install on that partition .... ))))
    And it finished Win 7 64 bit install without any further problems ...
    Now I'm downloading all the HP drivers - that is another crying game ....
    But , hey , we're almost home now .......
    PS the DVD drive is in order ....
  • claws77
    FX553VE-DM318T(FX553v) not POSTING
    by claws77
    Cpu i7-7700hq Ram - 8gb samsung, 32 gb sk hynix
    Gpu - nvidia geforce 1050ti
    Ssd orion o700
    Hdd hgst721010A9e630
    See images
    What's not working right?
    The system does not even POST, display is black,
    LEDs on - power led, aiplane mode, capslock fpr few seconds in the start(when connected to ac power) only.
    When did the problem happen?
    My laptop had dual boot setup, ubuntu and windows 10.
    It already had a moklist error, that would occur when i tried to boot ubuntu.
    05-17-2025, 04:09 PM
  • eccerr0r
    uefi boot from non GPT disks?
    by eccerr0r
    Any opinions on how many bios implementations will boot UEFI system partitions that are on MBR disks?
    I'm beginning to find perhaps that there indeed are UEFI firmware implementations that won't boot off of MBR disks that have an ESP (flagged with 0xEF). Some do and some don't, some will definitely boot off of removable media with MBR and 0xEF ESP but not hard drives...
    Is there a rule that GPT partitioning is required for hard disks to boot? Seems that CDROM (El Torito) and removable USB media do not need to be GPT, and MBR is fine?
    03-27-2022, 05:57 PM
  • privato89
    Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
    by privato89
    I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
    Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
    Let's begin:
    Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
    03-26-2024, 06:37 AM
  • Topcat
    Topcat's Supermicro X10DAI Build - Plus NVMe BIOS Mod Inside
    by Topcat
    Yes, I know I don't post this stuff much anymore....the only reason I'm posting this one is because of a NVMe adapter incompatibility; seems rather planned by Supermicro.....or I'm atleast a bit suspicious. It's plenty new enough to have a UEFI bios but a short 'happy list' of NVMe controllers that will work with this board, as if by some 'miracle', all Intel....so lets start at the beginning; we'll get back to this later.
    Of course the motherboard is as the thread title states; X10dai....but we'lre going to have some fun shoehorning this into a modern 'gamer case' that can actually...
    09-29-2024, 03:55 PM
  • Luke Anders
    Lenovo Legion 5 (15ACH6H/17ACH6H) - Does not boot into any OS
    by Luke Anders
    A few details about the laptop itself:
    Name: Lenovo Legion 5
    Model: 15ACH6H (according to its back cover details) / 17ACH6H (according to the BIOS Menu)
    BIOS Version: GKCN60WW
    EC Version: GKEC65WW
    Serial Number: PF39AQ7Z
    Board Model: NM-D562 Rev 3.0
    RAM: 16GB Installed, DDR4 (brand new)
    NVME: 500GB NVME drive (brand new, installed Windows 10 onto it for testing purposes and tested on another laptop (a dell XPS) works perfectly fine and boots in)
    I bought this laptop recently from eBay as a faulty device....
    10-12-2024, 05:13 AM
