Compaq 6715b work with battery only
  • hispeck
    • Aug 2015
    • 258
    • nigeria
    Hello friends, this laptop was working fine till after someone plugged ln a wrong charger, now only work with battery. I need help on how to fix it please
    • 20695
    Re: Compaq 6715b work with battery only
    Get the schematic and test the first mosfet after the DC in jack .
    • hispeck
      • Aug 2015
      • 258
      • nigeria
      Please don't have the schematic, and don't know which mosfet, can you give me the schematic and show me please
        • 20695
        It would help if you would include more details, such as board part number. Without it we can only guess which schematic you want .
        • hispeck
          • Aug 2015
          • 258
          • nigeria
          6050a2198501-mb-a06 the board no
          • dhs6512
            Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 not work with the battery
            by dhs6512
            Hello. Lenovo Legion 5 15ARH05H, NM-D281 Rev: 1.0 board
            Initially dead. Inspection: the board was not touched, on EC IT8227E-192 2101-CXA there is a mini-burnout.
            Replaced with the same one, flashed the EC with the official firmware (had to solder to the pins), left the main firmware (Gigadevice 25LB128DSIG) original.
            When connecting the charger, the device started, gave picture and works, checked all the functions - ok.
            Connected the original battery. Only on the battery the device starts for a second, lights up the keyboard backlight and turns off.
            When connecting...
            10-29-2024, 11:04 AM
          • mkdj
            ASUS X571 no power : battery issue?
            by mkdj
            Mark and model: ASUS X571
            Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
            Tests already made:
            - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
            - I have removed...
            07-14-2025, 09:16 AM
          • pabloroggeri
            Lenovo V310-15ISK - It doesn't work after changing the battery
            by pabloroggeri
            Good guys. I changed the battery to a Lenovo V310-15ISK.
            The laptop worked perfectly, I changed the L15C4A02 battery because it didn't last very long.
            When I connected the new battery, the charging LED stopped lighting up and the one next to the charging pin also did not react when I pressed the power button. Minutes before changing the battery it worked perfectly and stopped working after putting the new one in. Even if you put the oroginal battery in or connect it without the battery, no LED lights up when you press the power button nor does it give an image, nor does the...
            08-23-2024, 12:01 PM
          • techfreak9356
            Vostro 3400 (LA-K033P) won't charge battery, everything else ok
            by techfreak9356
            I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
            09-14-2023, 11:10 PM
            HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) Compaq Elite 8000 E5500 Specification for Upgrade or Repair
            This specification for the HP Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) boardview and Compaq Elite Compaq 8000 Elite Convertible Minitower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request...
            09-12-2024, 03:44 PM
