Lenovo G50-70 - power on problem
  • DeniS182
    • Jun 2014
    • 328
    • Slovakia
    #41
    Re: Lenovo G50-70 - power on problem
    Now I have gpu_core also 1.05VS, CPU_core etc.. fan spinning normally, cpu and gpu heat little bit, but still only black screen.
    • MJ-meo-dmt
      • May 2016
      • 186
      • South Africa
      #42
      Nice @DeniS182. When you say black screen, not just the back-light that's gone? I mean you tried it on ext display as well I assume?
      Sure the RAM is okay?
      LVDS connector and power okay?
      while alive { live(toFullest=true) }
      • DeniS182
        • Jun 2014
        • 328
        • Slovakia
        #43
        I looked better and my LCD is going on and off -without backlight, I mean only black picture is here, because I can't see Lenovo logo. LVDS connector looks fine I measured something:
        PIN 1 - +LEDVDD = 19.8V
        PIN 16 - INVT_PWM = 0V no pwm here
        PIN 20 - +3VS = 0V
        PIN 21 - +LCDVDD_CON = 0V
        PIN 23 - +3VS = 3.3V
        PIN 30 - +3VS_CMOS =3.3V
        Measured without LVDS cable connected.
        Nothing on hdmi output.
        • piernov
          • Jan 2016
          • 4435
          • France
          #44
          Is it even booting? At least POSTing?
          • MJ-meo-dmt
            • May 2016
            • 186
            • South Africa
            #45
            PIN 20 - +3VS = 0V
            Hmm Interesting... I had something like this not too long ago... Can't remember the make or model.... anyways...
            I found a little control circuit on that board that waited for a signal from the PCH to enable or start LED. I never got it to send the signal from the PCH (or EC...) ?? Not sure I'll go check if I can find anything similar in your schematic.
            And nothing on HDMI you say? Uhm sounds suspect as well towards the PCH... What about VGA? Also all this assuming the rest of the things work fine (the previous issues)
            EDIT: Look at Sheet 33.
            signals: PCH_ENVDD | PCH_EDP_PWM | PCH_ENBKL
            Check if you get those. Though It could be that you get the signals for a second.. as you said: "my LCD is going on and off" and it goes off again because something else is then causing a halt...
            Sheet 4: LCD_BKLT_CTRL_R todo with INVT_PWM
              • 20781
              f you connect the LVDS cable what voltage do you have at pin 20
              • s_specialist
                Lenovo E15 Gen 2 GE4B0 GE5B0 NM-D011 Rev 1.0 sometimes not opening problem
                by s_specialist
                Recently, I have started to encounter a problem with Lenovo E15 Gen 2 models not opening. When you try to open the device, it gives a warning sound and does not display an image, when you apply light pressure on the keyboard, the image appears and works for a while, when you turn it off and on, the same thing happens again. Bios was tried, RAM slots were cleaned and soldered to the legs, the problem still persists. There seems to be a problem with the onboard processors, but since Lenovos glue the processor firmly from the sides, the paths are very damaged when removing it. Has anyone encountered...
                07-07-2025, 11:47 AM
              • perzyk23
                Lenovo T580 - LCD Panel problem - error 0288
                by perzyk23
                Good morning,
                I have a problem with Lenovo T580, which after error code 0288 suggests a problem with the display. I checked the display and it works on another laptop. I replaced the display cable with a new one. I programmed another BIOS (downloaded from this forum) and I still have the problem of a dead display - there is an image via HDMI, and the system does not detect the built-in LCD at all. The problem appears to be hardware. What can I check to confirm or disprove this? I found many threads on the Internet related to this problem 0288, but without specific solutions. Please advise....
                10-25-2024, 12:42 AM
              • konradx
                Lenovo Thinkpad T15 Touchscreen problem bios
                by konradx
                i have problem witch Lenovo T15, my LCD display was demaged, i buyed New LCD, Touch screen version. Problem is LCD Working but Touchcreen not working, i wrinted to seller . He sended to me another LCD, but still not working. I have to Lenovo T480s with touchcreen LCD and that display and touch work. I think that is somethink like whitelist support LCD in BIOS. Someone have the same problem?
                That is my DUMP.
                My device:
                SN: PF29Y4N6
                1s20S7S2WF00PF29Y4N6
                MB: GT4A0 GT5A1 GP4A0 GP5A1 GT4A2 NM-C931 REV 1.0...
                09-06-2024, 01:33 AM
              • madrali
                lenovo e15 gen2 bios ? problem
                by madrali
                Model: Lenovo ThinkPad E15 Gen 2 (Intel)
                20TD-50S0KU00
                Hi, my laptop suddenly shut down while it was running. When I try to turn it back on, the screen stays black and it emits a melodic beep.
                I used Lenovo's SmartBeep decoder and it returned error 0284:
                "TCG-compliant functionality-related error (possibly BIOS code validation failure)"
                I then tried to enter crisis BIOS recovery mode by pressing Fn + R at boot. The melodic error code changes, but nothing else happens regardless of whether a USB is inserted. I receive another...
                06-16-2025, 12:06 PM
              • Ziome3eknh
                Lenovo x1 carbon problem
                by Ziome3eknh
                Hello, I have a problem with this computer.
                After connecting the power supply, the keyboard lights up and the touch bar works, you can click on it and it even illuminates the keyboard. When the fan is turned on, it turns on and off. the processor heats up. I have tried different bios but with no success, the same signs. It doesn't charge the battery either. when starting, it takes 20v and about 0.650a, after some time it drops to 0.350a and 5.2w. Has anyone solved the problem with this model?
                Will it be a RAM or CPU problem?
                below is the computer details
                Lenovo x1 carbon...
                01-29-2025, 02:35 AM
