HP dv7-7133nr No Video Problem Goya/Balen
  • alextech
    • Oct 2018
    • 38
    I have a hp Goya Balen motherboard, I am a beginner to repairing motherboards. The motherboard turns on but no video, also this motherboard does not have a GPU. The question I would like to ask is what do I have to look for? It seems to me like most people would think that the problem would be the GPU, but I know it would not be that. I have checked the capacitors under the CPU and some appeared to be shorted to ground, but to make sure it wasn't I took it off the board and they were not shorted to ground. I am curious if this would be a resistor or a bios issue? I did find a schematic for Goya/Balen, but the schematic is for motherboards with GPU.
    • 20807
    Re: HP dv7-7133nr No Video Problem Goya/Balen
    Post a close up picture of the area around PU4002 ,SPR5,PL4001 , and a second picture to the right of PL4001
    • alextech
      • Oct 2018
      • 38
      It was kind of hard to get a focus when getting close, is this good enough? I checked the coil and there is open line and no beep on that coil. I do see like a little black dot between PU4003 and PL4001, not sure if its a burn or not.
        • 20807
        Clean up that whole area with a brush and 100% IPA alcohol. Check voltage on PU4004 and PU4006 pins 1,4,8 . Use the attatched schematic for reference
        • alextech
          • Oct 2018
          • 38
          Ok I have an update, apparently when I was checking the board I accidently shorted a capacitor with the dc in connector and resulted in no power. I shorted a cap that I touched and a diode 330 that I did not and replaced but still have no power. I bought a power supply to see if it could help me find a bad component. I checked for voltage on PU4004 AND PU4006. It appears that all pins have 3 to 4 volts except for pu4006 top pins have 19v. the volts are jumping back and forth by 1 on the 3 to 4 volts. I have not looked at the schematics just yet, I have been busy. I will get back once I have time.
          • alextech
            • Oct 2018
            • 38
            Ok so I decided to make 2 videos to see whats really going with volts and continuity:
            Continuity mode - https://youtu.be/BoEGsMrGTMg
            Volts mode - https://youtu.be/khCbiGNBne8
              • 20807
              Its likely that PU4006 is damaged. Remove PU4006 and PU4004 from the board and test them .
              • alextech
                • Oct 2018
                • 38
                Ok I was not sure how to test PU4006, so what I did was check continuity on pins 1 2 3 and 4 and there is no beep. Also I saw a video of a very similar board with no power and had same PU4006 transistor and he basically jump the other side to pin 2 and he had power. However I tried that and it did not work. After putting the transistors back, I am now getting 12 and sometimes 15 volts on PU4004 leg 1, but on pin 2 3 4 5 6 7 8 are 1.2 and sometimes 1.5 volts. How is this possible? Also I checked coils in ohms and the back of the board all have open line, but in the front there about 100 ohms.
                Here is video checking ohms: https://youtu.be/DzV8nn04Yz4
                Here is mb similar problem: https://youtu.be/mAFrdkbnTz0
                I have ordered transistors and will change if needed.
                • alextech
                  • Oct 2018
                  • 38
                  Correction: PU4004 pins 1 2 3 4: .3 and .4 v (jumping up and down)
                  5 6 7 8: .9 volts
                  PU4006: pins 1 2 3 4: .3 and.4 v (up and down)
                  Pins 5 6 7 8: 19 v
                  • alextech
                    • Oct 2018
                    • 38
                    Ok, so I replaced the PU4006 and PU4004 and still no power. The reading on PU4006 leg 5 6 7 8 is 19v and the 1 2 3 4 are no volts. The reading on PU4004 leg 5 6 7 8 are .9 volts and leg 1 2 3 4 are no volts. The volts are not going up and down anymore. Would I need to use a power supply to load amps on PU4006?
                      • 20807
                      No ,don`t inject power just yet. Check volts on pin 6 of PU4001, then disconnect all power and test ohms to gnd on pins 1,2,3,4 and 6 .
                      • alextech
                        • Oct 2018
                        • 38
                        Ok, so you said PU4001, I think you probably meant PU4002? There is no PU4001 on this board. I took pictures to clarify what you meant. A little bit dirty due to the unclean flux I put. Another note PC4025 has 66 k Ohms on one side but the problem it not the capacitor itself.
                        • alextech
                          • Oct 2018
                          • 38
                          Ok, so when you said PU4001, I believe you were referring to BQ738
                          Ok PIN 1 on BQ738/BQ24738 (same), schematics says its PU4001 but on mb is not shown.
                          VOLTS:
                          PIN 1 - .9 v
                          PIN 4 - no volts
                          PIN 6 - no volts
                          OHMS:
                          PIN 1-4 Open Line
                          PIN 6 60 k ohms
                            • 20807
                            PC4010 looks burnt. SC2D2U25V5KX , 2.2uf 25V .Replace it and do the same tests.
                            EDIT: PQ4003 on the board looks like it has a burn mark on the top
                            • alextech
                              • Oct 2018
                              • 38
                              PC4010 and PQ4003 looks like that because of the no clean flux I used, I thought I bought the flux I was looking for like they use at my job but it wasn't. I put too much thats why it looks like that, I left a note for that. I will try to clean it more. PC4010 I was going to replace but realized there was still 66 k ohms on the board, so I decided to put it back. I need to check SC2D2U25V5KX, Is this not shown on the picture or are you referring to PC4010? I will replace PC4010 just in case though.
                                • 20807
                                PC4010 is on the board.On your picture at post #12 it looks burnt or its not seated across both pads. PC4010 on the schematic has the part number SC2D2U25V5KX.You need to replace the BQ24738 , its not going to be easy though if you`ve never soldered a QFN IC before.Practice first on some other scrap boards,watch youtube videos, use plenty of flux and a fine tip on the soldering iron.
                                • alextech
                                  • Oct 2018
                                  • 38
                                  Thanks for letting me know to practice on that one, I will practice with some scrap boards before I change it. I replaced PC4010, should look a lot better now.
                                  • alextech
                                    • Oct 2018
                                    • 38
                                    Ok I changed BQ738 and here is the volts and ohms on the pins, still wont power on:
                                    1 .9 v
                                    4 30mV
                                    6 2.6 v
                                    1 4 ohms
                                    2 4 ohms
                                    3 4 ohms
                                    4 OL
                                    6 60 k ohms
                                    Also I have a pic where the short happened and the BQ738 IC chip that I replaced:
                                    • Techtiger
                                      • Oct 2014
                                      • 1601
                                      • france
                                      BQ24738 is not correct
                                      pin 1=19v
                                      pin 2=19v
                                      pin 3=19v
                                      pin 4= must be high to operate N Channel mosfet to by pass voltage above 20V
                                      pin 6=2.7v
                                      remove PT4601 cap and test it
                                      • alextech
                                        • Oct 2018
                                        • 38
                                        I forgot to mention PT4601, I did tested it when I removed and was short and I did replace.
                                        • Biostechnology
                                          HP dv6 Envy (Goya/Balen 1.0 DDR3 11254-3) charging problem
                                          by Biostechnology
                                          11254-3 charging problem
                                          off condition enable to charge . when i turn on unable to charge batter plz help...
                                          04-23-2024, 04:47 AM
                                        • Spikeman
                                          Help on Video Problem on Dell Inspiron 7459
                                          by Spikeman
                                          Hi, I'll tell you the story of this PC.
                                          The PC was repaired because it had a shorted power supply. What happened was that the plastic covering the buffer battery positioned by the manufacturer on the capacitor melted, thus generating a short.
                                          After the repair, the PC worked, I installed Windows 11 and I may have had some problems with the video drivers, but after a bit of tinkering I think I solved them.
                                          However, the PC later presented the problem in the video shared very frequently.
                                          The problem also occurs at startup, in the bios and when using it as a monitor thanks...
                                          02-27-2024, 10:17 AM
                                        • Gibon378
                                          Problem with stopping audio and video for no reason
                                          by Gibon378
                                          PC Specs:
                                          • CPU: Ryzen 5 1600
                                          • GPU: GTX 1080 Palit JetStream
                                          • MOBO: ASRock ab350 PRO4
                                          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
                                          • PSU: XFX 650W (don't remember what model)
                                          • OS SSD: ADATA SP920
                                          • OS: Windows 10 21H2
                                          Problem description:
                                          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
                                          11-19-2022, 09:41 AM
                                        • zimeyh
                                          Problem video A1502
                                          by zimeyh
                                          Hi guys! I have a problem with macbook pro A1502. This display have a apple video, when launch desktop, this display is off. A connect thunderbolt a monitor, have video and laptop and monitor. Disconnect thunder video power off. Whats problem? 🤦🏻*♂️ thankss
                                          11-15-2023, 03:19 AM
                                        • hugocarmo
                                          Grundig GV-250 Repair problem. (Video inside post)
                                          by hugocarmo
                                          Hi everyone.
                                          I have the following problem.
                                          I have a Grundig GV-250 VCR which has not been used for over 10 years. When I turned it on, the fuse of the PSU burned out, after being replaced it burned again, I ended up verifying that I had the bridge rectifier and the mosfet in short, I ended up replacing it, and I replaced all the electrolytics of the PSU. However, it started to behave strangely, as I will show you in the video that I will attach as a link.
                                          In short, I ended up replacing all the ICs on the power supply CNY17G, TDA4605, TL431, TDA8137, TL082CP, AN3824K, L2720,...
                                          01-19-2023, 06:46 AM
