HP pavillion dv6 1210sa charger
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hello all,Can i have some friendly advice,Im in need of a replacment charger,for my laptop (model above) i have found one but the Amp are lower than the original 19v 4.74a,compared to my 3.34a 19v ? will it work ?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: HP pavillion dv6 1210sa charger
    do not buy that AC adapter, because it may damage the mainboard. I recommend buying an AC adapter with even 5 or 6 Amperage.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      It will work but still not recommended to buy. Better get 4.7A adapter.
      • alas3376
        • Nov 2011
        • 382
        • BENIN
        It will work, but will charge slowly. I dont recomand it
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          I have used this company before i know there made in china (uk stock) but they seem too do the job ok
          https://www.ebay.co.uk/itm/NEW-AC-CH...-/190798089086
            • 21932
            I`d buy a 2nd hand (used) genuine charger from ebay or a pc shop .Used quality chargers are better than compatible or replacement chargers.
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              this looks a genuine charger and good price
              https://www.ebay.co.uk/itm/GENUINE-H...8AAOSw4klbabqy
                • 21932
                Probably a fake,with a metal plate inside to make the weight up. I`d still buy used,and ask the seller if its the charger that came with the laptop originally.
                EDIT: and also ask the seller if there`s any splits or fraying.
                https://www.ebay.co.uk/sch/i.html?_f...p2045573.m1684
                • motormayhem
                  Lenovo T460 Only Charges on One Charger
                  by motormayhem
                  Laptop Question
                  I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                  A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                  05-12-2023, 01:46 PM
                  NVDC charger configuration...
                  11-05-2024, 03:28 PM
                • flat-earther
                  how to prevent a connected charger from draining battery when not charging?
                  by flat-earther
                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                  So the battery is backfeeding the charger and being drained.
                  How can I prevent...
                  08-07-2025, 01:04 PM
                • flat-earther
                  ASUS X54H laptop thinks it's always charging even with charger unplugged
                  by flat-earther
                  The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                  Windows also shows ''Plugged in'' when charger is not connected.
                  This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                  Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                  If I let battery run out and say it has 3% Windows will...
                  06-24-2025, 09:32 AM
                • coasterghost
                  Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                  by coasterghost
                  For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                  Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                  Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                  System Hardware:
                  Processor: AMD Ryzen 7 PRO 5850U
                  Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                  09-08-2025, 10:46 PM
