T540p no power
  • RethoricalCheese
    • Mar 2013
    • 1519
    • Estonia
    T540p no power
    Issue: No power
    Possible reason: Slight liquid damage (corrosion) on C8286/C8285 and near C611.
    Damage cleared, seems nice now, but still the same problem. Liquid damage might be just a coincidence.
    No power on BIOS chips.
    Unable to find 3V3 and 5V ALW.
    There is 3V present on power button.
    Any idea where to look or is there a schematics available?
  • caspian
    • Oct 2015
    • 1592
    • Laptop
    Re: T540p no power
    what is the mainboard ID?
    • RethoricalCheese
      • Mar 2013
      • 1519
      • Estonia
      Re: T540p no power
      Oh, sorry, forgot to add that:
      LMK-1 SWG2 MB
      12308-2
      48.LO16.021
      • RethoricalCheese
        • Mar 2013
        • 1519
        • Estonia
        Re: T540p no power
        Almost a year later I received another T540p with similar fault.
        When I connect the charger, power button blinks 3 times. Laptop will not turn on. 3V3 present on power button, goes low when I press it.
        3V3 and 5V are present when battery is connected but there is 0V on both of the BIOS chips. 19V from charger is present. Battery is being charged.
        Did not find any shorts on inductors.
        CMOS reset done.
        I am out of ideas.
        • mylocky
          • Jun 2014
          • 18
          • hungary
          Re: T540p no power
          In 2023 this problem is still on. Can you find any solution for that?
          • bachir2004
            • Feb 2015
            • 439
            • maroc
            Re: T540p no power
            CMOS reset done.
            I am out of ideas.[/QUOTE]
            Had one t440 2 hours ago same problem 30 minutes struggling with the mobo nothing like dead not even 3.3v on battery connector,nothing on bios chip.Finally removed the cmos battery plugged in the charger and it ran like normal.reconnected the cmos battery and it still runs ok.Have you checked the two first mosfets near power connector?
            • speggio91
              Macbook Pro 2020 820-01949 No power/Cycling Liquid Damage
              by speggio91
              Hi everyone, I’m troubleshooting a MacBook Pro 2020 Intel logic board 820-01949 with liquid damage on the USB-C ports side. The spill was mainly in the area near U8320_SWR, U8300_SWR and U6300, and there were a few nearby SMD ceramic capacitors that looked dark/blackened. The area around U3100_R did not look heavily affected visually, but the problematic port seems to be associated with that controller.
              The symptoms are the following. If I plug a USB-C PD charger and a USB-C ammeter into the two ports on the damaged side, one port stays at 5V and draws about 0.25A steadily and never...
              02-07-2026, 10:30 AM
            • tommy97
              A2337 No power - Liquid damage 5V (820-02899-A)
              by tommy97
              Hi guys,
              We're having an issue with an A2337 following liquid damage.
              Both CD3217 ICs were severely liquid damaged, so we replaced them. Initially, UF400 was stuck at 5V 0A, while UF500 negotiated to 5V 0.2A and then restarted. FF200 measured 0V.
              We then replaced the PPVBUS_USBC0 diode, which restored 5V. However, the behaviour remains the same on both USB-C ports: current rises to 0.2A, stays there for a few seconds, and then drops back down.
              The laptop now powers on from the battery. With only the trackpad connected (and no battery attached),...
              06-14-2026, 04:22 AM
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • bloodhound
              Acer C27-1655 no power after liquid damage
              by bloodhound
              Hi!
              I´ve got an Acer C27-1655 AiO computer for repair on my bench.
              Mainboard: AX1T_MAIN_PCB
              The liquid was mainly in the area of MQ1, the voltage regulator for +VDDQ_MEM (pictures attached).
              Symptoms:
              When power is connected and power switch is pressed, I get 5V at L1, 3.3V at L2 and 1.8V at LPM5. I also get V1.05A_BYPASS at R442 for PCH.
              I also measure 2V on +V1.8U_2.5U_MEM but +VDDQ_VTT and +VDDQ_MEM stay at 0V. +V1.8U_2.5U_MEM is also drawn to 0V if RAM memory is installed.
              LPM1, LPM2 and LPM3 stay at 0V.
              +VDDQ_MEM...
              11-19-2024, 05:23 AM
