Acer C27-1655 no power after liquid damage
  • bloodhound
    • Jun 2015
    • 10
    • Austria
    Hi!
    I´ve got an Acer C27-1655 AiO computer for repair on my bench.
    Mainboard: AX1T_MAIN_PCB
    The liquid was mainly in the area of MQ1, the voltage regulator for +VDDQ_MEM (pictures attached).
    Symptoms:
    When power is connected and power switch is pressed, I get 5V at L1, 3.3V at L2 and 1.8V at LPM5. I also get V1.05A_BYPASS at R442 for PCH.
    I also measure 2V on +V1.8U_2.5U_MEM but +VDDQ_VTT and +VDDQ_MEM stay at 0V. +V1.8U_2.5U_MEM is also drawn to 0V if RAM memory is installed.
    LPM1, LPM2 and LPM3 stay at 0V.
    +VDDQ_MEM & +VDDQ_VTT don´t show any shorts to ground.
    I don´t know if it is normal or not in this stage of the power cycle, but PCH/CPU gets a hotspot with about ~50 °C.
    In my opinion, the liquid in the area of MQ1 led to a overvoltage at the memory voltage part, causing a fried PCH.
    What do you think?
    Do you have any suggestion?
  • bloodhound
    • Jun 2015
    • 10
    • Austria
    Here is the schematic of the board: Schematic moved to new thread - https://www.badcaps.net/forum/troubl...1655-schematic
    • mon2
      • 14726
      Usually a show stopper but wait on other comments.
      • bloodhound
        • Jun 2015
        • 10
        • Austria
        I might have come to a conclusion a little too fast.
        I didn´t see, that the buck converter is fed by +V5A and +V_DC.
        I measured these and I get everything. So +V5A, +V_DC and also +V3P3A is there:
        So it´s possible, that only the buck converter is busted.
        What do you think?
