Dell 5520 problem
  • sandrabrnelic
    • Mar 2012
    • 34
    • Croatia
    Dell 5520 problem
    Hi !
    I have problem with Dell 5520 15" laptop.
    Laptop has this motherboard ... https://cdn.badcaps-static.com/pdfs/...a856347d78.pdf
    When i try to turn it on it spins fan for 3-4 seconds, power led goes on, 3 leds above keyboard (upper right corner) are lit in some sequence and after that fan stops and power led remains on. Screen is black. I tried to connect monitor on VGA port but there is no image. I tried to power it on with battery and charger in a any combination. Result is allways same.
    To power it on i have to short pins 3 and 4 on JPWR connector because it also has some problem with power button board or cable.
    Anybody has idea what to check first in case like this.
    Thank You !
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Dell 5520 problem
    which voltage rails are missing?
    • sandrabrnelic
      • Mar 2012
      • 34
      • Croatia
      Dam'n thing ... while i was measuring voltages it suddenly turned on and now it's working but i believe that it will die again, because i didn't do anything. It must be some bad conection on motherboard or ???
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • Cicciotest
        DELL IPCML-CT rev a00 pOWER ON PROBLEM
        by Cicciotest
        I have a problem with this dell mini desktop, no LED lights up and there is no response from the front power button. It literally feels defunct, with no feedback whatsoever.
        IPCML-CT motherboard rev.A00
        CPU: Intel Celeron G5900T
        I tested the power supply (19.5v correctly) but to be careful I also used an alternative power supply to test, nothing. No LEDs, no power on.
        I tested the power button pins and they correctly measure 3.3V, so when I press the button or put a bridge with a wire, the pulse seems to be there correctly.
        06-06-2024, 08:48 AM
      • Mark01
        Dell Optiplex 7490 AIO - red power led after flash
        by Mark01
        Hi guys,
        This is my first post! 🚀
        I have no idea what I’m doing, but I’m learning by trial and error.
        I’m currently working on a Dell Optiplex AIO 7490—one of a bunch of AIOs that mysteriously failed to POST just a few days after the warranty expired. The original issue was that the PC worked fine until it was rebooted, after which it got stuck on a black screen (no backlight), with fans spinning at normal speed and a solid white power LED. Forcing it off by holding the power button would just cause it to switch on automatically and get stuck again on...
        07-04-2025, 12:54 PM
      • zlr8r
        Dell inspiron 17 (7786) - DP/N 09P7JP - odd power issues, starting with no power LED
        by zlr8r
        hey guys, hoping for some pointers to repair an eBay bought "faulty" laptop.
        Ill try and give as much info as I can.
        Dell Inspiron 17 (7786) Laptop
        Service Tag: 5J0NHT2
        Bios: 1.9.0
        When I received this , it would only flicker on the KB backlight for a second, then off and on.
        Then it started getting weirder!
        Sometimes when attaching the AC power supply, and pressing various pre-boot diagnostic keyboard keys... it did try to boot, in fact out of a hundred attempts, the laptop did actually boot into the Bios ! but never has...
        12-12-2023, 09:31 PM
      • mohamed mm
        Dell inspiron 5520, 7 beeps problem
        by mohamed mm
        I've an Inspiron laptop model 5520, board name, la 8241p, with a 7-beep problem.
        exist voltage:
        PL 200:3.3v
        PL 201:5v
        ram volt PL300: 1.5v
        PL600: 0.9v
        PL500: 1.0V
        PL 202: 19V
        Processor section:
        PL701: 1.2V
        PL702:1.2V
        but PL704: 0.0V
        and PQ705 / PQ706 are zeros on gate/drain and source.
        PC724/PC712 : 19V.
        bios volts:
        EN25QH16 / EN25Q32B: 3.3v.
        I tried to program a (W25Q32B) BIOS chip with an (EN25Q32B) BIOS dump from the internet, but during verification, it says
        08-22-2025, 07:13 AM
