Macbook pro 17" A1297
  • Eleways
    • Oct 2014
    • 62
    • Italy
    Hi guys
    I've a problem on a Macbook 17". Same Gpu problem, i suppose. After some minutes of work the image on display move on left side, I've change the Gpu, same problem.
    Any idea? I'm thinking about video memory, but it's strange.
    thanks Luca
  • rounin
    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
    by rounin
    🛠 Original Issue
    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
    04-19-2025, 01:18 AM
  • giove
    problem with keyboard macbook a1297
    by giove
    Hi, I have a macbook a1297 emc2414 motherboard 820-2914-B with password prompt on startup. I unmounted the bios chip and reprogrammed deleting everything after $SVS from the binary file. After reassembly it boots normally with the operating system. Unfortunately, probably by disassembling the motherboard, the keyboard no longer works.
    I have unplugged and plugged the connector several times but nothing to do not even the start button works. To start it I have to disconnect the battery and put the power supply connector. Is it possible that the keyboard broke? do you think replacing it works?...
    06-03-2023, 12:47 PM
  • psdavid65
    Macbook Air A1466 820-3437-B Booting Problem
    by psdavid65
    I received a 2013 Macbook Air A1466 820-3437-B motherboard with serial number C02L6GQ9FSV8 that came in WITHOUT a bios chip. I got a new bios chip and reprogrammed it. Macbook now powers on but doesn't boot the SSD. I've flashed a ton of bios but still same problem. Windows installation works with this Macbook but never a mac installation. Unfortunately, since I didn't receive this macbook with a bios chip, I don't have the original bios. What can I do now?...
    06-20-2024, 12:27 AM
  • Skrndelj
    Apple Macbook Air M1 A2337 Trackpad problem
    by Skrndelj
    Hello all,
    I am repairing a Macbook A2337 and i have a problem
    The Macbook is stuck in restore as someone before me tried a DFU restore and bricked the device, now i can't do a restore as AC2 throws error 1 which is related to the trackpad.
    When i turn on the device i get the trackpad click for a few moments and then nothing, i tried 7 trackpads and 7 trackpad flats, i know all 7 are functioning okay, especially one as i use it for testing and DFU restore.
    I inspected the whole board and everything seems fine.
    Can anyone help me as i didn't fiddle with trackpad...
    06-11-2024, 04:26 AM
  • sdogs
    Macbook Air 2020 A2179 820-01958 battery problem?
    by sdogs
    I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port intermittently).
    After a first inspection I could see that the D3302 protection IC was burnt out, so I replaced it but the problem was not solved, it seems like intermittent 5v input.
    I then replaced the two u3200s (CD3217B12ACE) and now I have stable 20 volts and the macbook has turned back on.
    Unfortunately I have a further problem, it works very slowly and the fan runs at maximum and if I disconnect the charger it turns off, it's as if the battery was disconnected.
    02-08-2024, 08:00 AM
