Macbook Air 000165 No P5VS4RS3_EN_L
  • BrickBreaker
    • 52
    Light on charger no fan spin.
    PP3V42_G3H - 3.430V (pin 1 R7095)
    PPBUS_G3H - 8.59V (pin 2 F7140)
    PP3V3_S5 - 3.324V (pin 2 L7560)
    PP5V_S5 - 0.0V (pin 1 L7520)
    PP3v3_SUS - 3.323 (pin 8 U6100)
    PVRTC_G3H - 3.324 (pin 1 U1900)
    P5VS4RS3_EN_R - 0.0V (pin 1 R7551)
    I changed U1900. No visible damage. The case has some liquid but board is clean. Liquid is all along the lcd hinge black plastic bar. RTC chip U1900 is common. Maybe I try touching up that job.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Air 000165 No P5VS4RS3_EN_L
    Resistance to ground of PP5V_S5?
    • BrickBreaker
      • 52
      Oh and the client said that it "just turned off unexpectedly" and wouldn't turn back on.
      • BrickBreaker
        • 52
        35.0 kOhm
        0.457 V Diode mode
        • piernov
          • Jan 2016
          • 4439
          • France
          Uhm… L7520 is PP5V_S4RS3, not PP5V_S5. PP5V_S5 is the LDO (VREG5) output of U7501.
          I guess PP5V_S5 is present and PP5V_S4RS3 is missing due to missing PM_SLP_S4_L.
          Check if the rails are pulsing or not. Check the usual RTCRST#, SRTCRST#, DSWVRMEN, DPWROK, SLP_SUS#, INTVRMEN, RSMRST#, PWRBTN# of the PCH. Check the SPI ROM traces and resistor. You said you replaced U1900 so I guess it's ok.
          Really no liquid damage on the board? There should be something somewhere and it would help us a lot.
          • BrickBreaker
            • 52
            O shiz you're right. I thought I measured again on the other side, C7505 right next to U7501. Oops, well that's my bad.
            You are right and PP5V_S5 is there at C7505. As far as pulsing, my multimeter is reading a steady voltage on all the power rails (3v42, ppbus, 3v3, 5v). Thanks for all the suggestions, I am going to try and find all those usual suspects and give readings.
            In meantime here is what I found. MOSI and MISO are not "talking." I have been told to look for this. I am referring to U6100 pins 2 and 5. Steady 3.319V on both. Also, PCH_CLK32K_RTCX1 is measuring .423V and I am told that it should be about 0.8V.
            • piernov
              • Jan 2016
              • 4439
              • France
              Sorry I was asking if the "next" power rails are pulsing, the ones you're missing, and PM_SLP_S4_L too.
              MOSI and MISO are very high speed communication lines, if you don't have a high-bandwith oscilloscope (100Mhz at least IIRC) you may not catch it. CS# pin is easier to measure and will also tell you if there is activity. If the power lines are not pulsing and if the traces and resistors of the SPI ROM look good the issue shouldn't be there. (BIOS can get corrupt but that's unlikely here)
              I'm not sure about the exact voltage of PCH_CLK32K_RTCX1 (may not show up the same on different multimeters as well), but if you replaced U1900 and you have PPVRTC_G3H, it should be ok. If still in doubt, replace it again and check the pads and traces.
              • BrickBreaker
                • 52
                Next as in S4?
                I meant to mention that I don't have a oscilloscope. I checked continuity along the traces for SPI ROM. I replaced U1900 twice already, first time with a new chip (from china of course) second time from parts board just in case stock was bad. Here were my readings.
                RTCRST#, 3.318V
                SRTCRST#, 3.318V
                DSWVRMEN, 3.228V
                DPWROK, 3.433V
                SLP_SUS#, 3.323V
                INTVRMEN, 3.229V
                RSMRST#, 3.294V
                PWRBTN# 3.427V
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Ok so everything is fine there.
                  Voltage on SMC_ADAPTER_EN and PM_BATLOW_L?
                  Make sure you really don't get any spike on PP5V_S4RS3.
                  • BrickBreaker
                    • 52
                    SMC_ADAPTER_EN - 3.431V
                    PM_BATLOW_L - 0.035V
                    PP5V_S4RS3 is flat 0.0 no spike.
                    • piernov
                      • Jan 2016
                      • 4439
                      • France
                      Plug in a known good battery and check again.
                      • BrickBreaker
                        • 52
                        Plugged in battery, got fan spin. I saw definite corrosion under SMC on Tuesday so I did a reball on SMC just now. After that, I get fan spin and cpu gets warm if I have a battery attached. On magsafe only I get the same as before, light on charger, no 5v no fan obviously. So now I know where to look, gonna maybe check that I get chime and stuff with battery. My thinking for the magsafe only problem is batt current sensing, ISL talking to SMC... Yea I'll update.
                        • piernov
                          • Jan 2016
                          • 4439
                          • France
                          Check if it boots fully with battery. If it does, don't forget to check if fan spins normally and that HWSensors report correct values. You're probably set and the computer is working properly.
                          About the AC adapter only issue, your Magsafe might not be recognized properly. Those boards are very picky about the Magsafe. Use an original Magsafe 2 60W. Don't try to dig further into a board issue before trying another known good Magsafe, and check if battery charges properly inside the computer.
                          • BrickBreaker
                            • 52
                            Bigups thanks for that. I will definitely boot it first and check out those things. For the magsafe only issue, the connector J7000 has PP5V_S4RS3 on pin 3. This is 5.1V without* the io cable plugged in. The fan spins as soon as i connect the charger too, if the io cable is not there. With the io cable = 0V on pin 3. Also if the Battery is attached, I can get 5.1V on pin 3 of J7000 even with the io cable attached.
                            • piernov
                              • Jan 2016
                              • 4439
                              • France
                              That's definitely an issue with the Magsafe. Some Magsafe aren't recognized properly with this board. On the other hand, if the computer runs fine and the battery charges correctly, don't bother to dig into this issue.
                              • mitchw
                                MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                by mitchw
                                Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                I quickly took it apart and washed the liquid residue off the mainboard.
                                The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                Now the laptop...
                                07-16-2025, 07:55 AM
                              • mon2
                                A1466 Macbook Air (Liquid damage repair)
                                by mon2
                                Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                Macbook AIR Model A1466 Diagnostic 09-01-2021
                                Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                Problems & Resolutions
                                1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                09-01-2021, 09:31 AM
                              • rounin
                                MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                                by rounin
                                Device Information
                                • Model: MacBook Pro 14” M1 Pro (A2442)
                                • Logic board number: 820-02443-05
                                Original Issue
                                The device suffered liquid damage, causing a short circuit on the logic board.
                                Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                                Work Performed
                                Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                                Current Status
                                • When powered on, the screen shows support.apple.com/mac/restore....
                                10-20-2025, 11:15 PM
                              • bigbadbios
                                a2338 2020 Macbook Pro liquid damaged won't turn on- weird issue
                                by bigbadbios
                                I am trying to fix this liquid damaged 2020 Macbook pro and I noticed something weird.
                                When I push on/around the renesas 501cr0b IC, which appears to be a clock generator/ multiplier, If I apply lot of pressure, the device will reach 19.9 volts and seems to be trying to work.
                                I have thoroughly reflowed that area and completely removed that chip (there was some liquid stain in that area) but no help. I have just 5v 0a unless I apply the pressure.
                                Your help is GREATLY appreciated. Thanks!
                                08-18-2024, 05:47 PM
                              • rilley
                                MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                by rilley
                                I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                And the resistor L4004 is literally burned.
                                From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                07-10-2024, 01:57 AM
