2015 macbook air keeps shutting down
  • robertpritchard
    • Dec 2016
    • 61
    i have a 2015 macbook air j113 820-00165 that keeps keeps shutting off i get green light on charger and turns orange when charging just wont stay running any help would be great
  • bjhawfam
    • 144
    Re: 2015 macbook air keeps shutting down
    Keeps shutting off? As in it will load into the OSX and than it shuts off?
    • robertpritchard
      • Dec 2016
      • 61
      yep lets me sign in then shuts off
        • 20914
        Hold down D when you start up, it will run some diagnostics,let us know the results .
        • robertpritchard
          • Dec 2016
          • 61
          it shuts off before it gets to the end of the line
          all power rails read normal must be a short somewhere
          • RJARRRPCGP
            • Jul 2004
            • 6304
            I suspect a faulty heatsink...
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
            • robertpritchard
              • Dec 2016
              • 61
              is there a way to test that
              • RJARRRPCGP
                • Jul 2004
                • 6304
                If it's seated properly, likely a broken vapor pipe...
                Arc A770 16 GB
                • robertpritchard
                  • Dec 2016
                  • 61
                  broken vapor pipe ??
                  • robertpritchard
                    • Dec 2016
                    • 61
                    are you talking about the heat sink shield
                    • RJARRRPCGP
                      • Jul 2004
                      • 6304
                      No, the sealed pipe that runs between fins.
                      Arc A770 16 GB
                      • robertpritchard
                        • Dec 2016
                        • 61
                        really 4,083 posts and you think a piece of sealed pipe is why my macbook dosent turn on.. wow anyway found my short and fixed now but thanks for the bright idea
                        • RJARRRPCGP
                          • Jul 2004
                          • 6304
                          I suspected the heatsink, because you got as far as login...
                          Arc A770 16 GB
                          • Romulo
                            • Nov 2016
                            • 484
                            • Philippines
                            can you share how you solved the problem and where is the short.
                            • twonk9098
                              Macbook Pro mid 2015 battery required to boot?
                              by twonk9098
                              I have read many forums that state the Macbook Pro 2015 needs / does not need a battery to boot. I'm not convinced as yet which is correct.
                              The Macbook Pro mid 2015 I have has no battery and do not really want to buy one just to test.
                              This model has the newer trackpad which is not clickable when turned off.
                              At the moment, without battery it does turn on with no display (with backlight), no chime and then turns off after 13 seconds. I see this from the power draw on my DTPS.
                              If I hold the power button whilst connecting the magsafe 2 charger it turns on, again no image but...
                              12-10-2024, 06:51 PM
                            • envym
                              MacBook Pro 2018 with Activation Lock
                              by envym
                              Hi everyone!
                              I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                              I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                              06-27-2025, 08:54 AM
                            • yura8
                              Need BIOS/EFI dump for MacBook Air A1466 2015 EMC 2925 (8gb)
                              by yura8
                              Hi there! I have not so usual situation...
                              I have 2015 MacBook Air A1466 EMC 2925 with 8Gb of RAM. It seams that I've killed it by bad SSD adapter. It starts, cooler works... But no chime, screen is black. SMC reset seams works, NVRAM reset doesnt works...
                              My repair guy has checked all possible. It's all ok with power. The last idea - I could kill EFI firmware... So, I need a firmware of EFI to check it. I have a programmer. But I don't have a similar laptop now to download it and compare
                              P.S. If you have else any ideas about repair, or you had a similar...
                              12-20-2024, 02:31 PM
                              Apple MacBook Air 13" Early 2015 Service Guide
                              Apple MacBook Air 13" Early 2015 Service Guide...
                              10-15-2024, 02:06 AM
                            • resistor83
                              SSD MacBook Pro 2015 not recognized and gets hot
                              by resistor83
                              Hi everyone, a customer brought me an original Apple SSD (mz-jpv2560/0a4) from a 2015 MacBook Pro to ask me to recover the data. He told me that the computer was taken to the Apple center but that there was a problem with the motherboard and therefore it could not be repaired....
                              However they removed the SSD so for try to recover data
                              I tried to insert this SSD into another 2014 MacBook Pro that I had but the SSD could not be seen either from the recovery or from an operating system started from USB (BigSur or El Capitan)
                              I also tried with a USB adapter but nothing
                              I also...
                              12-10-2023, 02:47 AM
