plz help dell 14z missing componenet
  • amr soliman
    • Oct 2015
    • 123
    • egypt
    ihave dell 14z-n411z mainboard (da0r05mb8d0 rev d) missing 3 mosfets pq4 & pq5 & pq1 and i/o u13
    any one have schematics or good pics for this mb
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: plz help dell 14z missing componenet
    Your mb is quanta R05. I 've schematic for quanta R02. Almost same. Hope it helps you.
    • amr soliman
      • Oct 2015
      • 123
      • egypt
      thank you i'll see and till you results
      • Bowline
        by Bowline
        06-11-2025, 10:13 AM
      • multitech
        Dell G7 7588 LA-E994P missing +VCC_CORE
        by multitech
        Hi everyone, i got a Dell G7 7588 missing +VCC_CORE and +VCCGT, i have already checked the power on sequency, everything seens to be fine, i also have PCH_PLTRST# signal present.
        the laptop turns on but no video.
        i flashed a new BIOS and also Clean ME, same issue.
        i already replaced PU5000 NCP81215D
        DRVON 4.75v
        VR_RDY 3.3v
        EN 3.3v
        +VCCSA 1.04v
        +VCC_CORE resistance is 4ohm.
        no GPU power also but if i remove the +VCCSA coil i have the GPU powered and the VRAMs.
        Thank you.
        01-31-2025, 10:32 AM
      • PacoGT
        i need schematic or help missing components DELL LA-C642P
        by PacoGT
        I'm looking for the schematic or the numbering of the components that are missing on this board since they brought it to the workshop but without the parts and I can't find the schematic or anything about this board
        DELL LA-C642P
        THANKS
        08-28-2024, 06:29 PM
      • Akhlz001
        by Akhlz001
        09-20-2025, 07:15 PM
      • master3112
        by master3112
        07-29-2025, 01:55 PM
