Reading ohm or uf
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Reading ohm or uf
    Seen low capacitance caps
    1uf 20v or xxv
    Using continuity it will buz but using ohms will reading show 0.01ohm
  • petehall347
    • Jan 2015
    • 4440
    Re: Reading ohm or uf
    try swapping leads over or discharging cap first
    • Nievatronix2021
      Acer ES1-432 (DA0ZQFMB6F0 REV 3) nominal ohms reading from +VCC_VCCGI to GND
      by Nievatronix2021
      Hi everyone, I just wanna ask anyone who have had this laptop model got successfully repair. I just want to know what is your good/nominal actual resistance (ohms) reading between +VCC_VCCGI to GND during Off state (S5). The schematic diagram is based on Acer Aspire ES1-432 Quanta DA0ZQFMB6F0 REV 3.
      TIA.
      01-24-2021, 02:37 PM
    • ResoluteHawk
      Quanta 0P5 (DA0P5HMB8E0-Rev E) Missing ACDRV
      by ResoluteHawk
      I have an HP 15-DY laptop in because the battery is not charging.
      If I use a charged battery, the laptop powers on but the battery will not charge, however the orange charge light does turn on. The laptop loses power as soon as I disconnect the battery.
      I've replaced the BQ247 chip with a known working one and I get the same issue and the same measurements.
      Measurements are as follows:
      BQ728 IC
      VCC (Pin 20) => 19V
      CMSRC (Pin 3) => 0.8V (This is a problem but I can't figure out what's causing the low voltage)
      ACDRV (Pin...
      04-10-2025, 11:36 AM
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • Curious808
      LG LST5651SW stove: oven not heating properly
      by Curious808
      LG LST5651SW stove: The oven has a hidden bottom (bake) element that seems not to be heating up, but tests OK.
      PROBLEM DESCRIPTION: Set oven to 400. The display shows it heating up normally to about 365, and stops there. The top (broil) element is visible and heated. Can't see the bottom element, but the bottom of the oven isn't extremely hot. A wet cloth on the bottom doesn't sizzle and doesn't really heat up. The stovetop burners seem to be working fine.
      TESTING SO FAR:
      1) Removed the back panel and leads to the bottom element. Using multimeter, continuity...
      01-07-2023, 02:37 PM
    • sarry86
      Hp Elitebook 1030 G1 power issue
      by sarry86
      Hello, I have this Hp pavilion 1030 G1 that starts with a single light on caps lock then it turns off, measurements at the coils, meter in resistance mode (not continuity mode) are as follows: The problem started just after it fell from a desk to the ground. I can't find a boardview or a schematic diagram anywhere, please help me 🙏
      1. 13k ohms
      2. 0.00 ohms
      3. 6.7 ohms
      4. 8.9 ohms
      5. 18.2 ohms
      6. 83.5 ohms
      7. 99.4 ohms
      8. 10.7k ohms
      9. 68.5 ohms
      04-26-2024, 05:54 AM
