Acer ES1-432 (DA0ZQFMB6F0 REV 3) nominal ohms reading from +VCC_VCCGI to GND
  • Nievatronix2021
    • Jan 2021
    • 16
    • Philippines
    Hi everyone, I just wanna ask anyone who have had this laptop model got successfully repair. I just want to know what is your good/nominal actual resistance (ohms) reading between +VCC_VCCGI to GND during Off state (S5). The schematic diagram is based on Acer Aspire ES1-432 Quanta DA0ZQFMB6F0 REV 3.
    TIA.
  • Nievatronix2021
    • Jan 2021
    • 16
    • Philippines
    Re: Acer ES1-432 (DA0ZQFMB6F0 REV 3) nominal ohms reading from +VCC_VCCGI to GND
    Problem solved I bought 2ndhand board online. Readings shouldn't be shorted to ground.
    • narf
      Epson EB-U42 projector / Caps with 0.7 ohms ?!
      by narf
      hi all,
      first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
      i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
      what i've found so far:
      - the PSU does its job and supplies 12V to the mainboard via the connector.
      - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
      - not far away, there's the first cap with a resistance of 0.7 ohms....
      07-02-2024, 03:53 PM
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
    • Sephir0th
      DELL XPS 15 9560 - No VCore, Power Off after few seconds
      by Sephir0th
      Hello Community,
      i'm troubleshooting this one since days and actually i'm really lost because i believe i'm Missing the required experience for an issue Like this...
      It is a Dell XPS 15 9560, i7-7700HQ, GTX1050 Board Number LA-E331P Rev 1.0, Most similar to LA-C361P so i use this Schematics.
      Issue: Starts and shuts Off after a few Seconds. Basic Troubleshooting (Adapter,RAM,BIOS/EC Flash from alisaler) of course already done, which didn't Changed anything.
      I have another working Board with i5-7300HQ and GTX1050, with It's Help i can compare...
      05-09-2021, 11:22 AM
    • Nagyesz
      Lenovo ideapad 330ICH - Dead, no volts on coils
      by Nagyesz
      Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
      I've never encountered something like this before;
      No charging light, full dead
      Lenovo Ideapad 330-17ICH
      • PL3102: 5 ohms
      • PL3001: 3.2 ohms
      • PL3101: 2 ohms
      • PL5801: 3.5 ohms
      • PL5501: 270 ohms
      • PL701: 35 ohms
      • PL501: 146 ohms
      • PL503: 390 ohms
      • PL402: OL (0.27V) +5VALW_P
      • PL301: OL
      • PL401: OL (0.03V) +3VALW_P
      + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
      10-11-2024, 10:12 AM
    • BustinCaps
      Dell 2007WFP resistors under white silicon blog
      by BustinCaps
      My beloved 2007WFP just died on me. It has a green blinking light that just cycles through various display numbers. For a while I noticed it would blink slightly like the refresh rate was off. Nothing I have done has been successful in turning it on. So I took it apart and looked at the USB board since many people have had problems with the resistors under the silicon blob. I looked at the various other boards for the obvious signs such as blown caps, bad fuses, burn marks etc. Nothing looked obvious. I also checked most of the caps with an ESR meter and they checked out good.
      04-29-2022, 06:19 PM
