820-3437-B loud fan & hot U3900
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Hey, everybody!
    I have an 820-3437-B board that doesn't power up properly. The charging light goes from green to orange, and the fan powers up, then slowly ramps up to 100% speed. I get all S0 rails active at this point (at least 5V and 3V3, anyway). As soon as I plug in the adapter they appear, then a few seconds later they go to 0V for a couple seconds, then come back and stay while the fan spins 100%. While I was measuring, I noticed that U3900 gets very hot, so I tried reflowing it, then removing it and putting it back on. It is possible that I reinstalled it improperly, as I'm still working with a heatgun and tweezers, but I still have the same symptoms after doing that, and it passes a visual inspection and I can poke at it and it doesn't come off.
    Does anybody have an idea as to what I should check first?
    Thanks!
    • 20869
    Re: 820-3437-B loud fan & hot U3900
    How did you put U3900 back on ,did you use a stencil.
    • Flippers McCoy
      Tinkerer
      • Mar 2018
      • 106
      I haven't done BGA work before and almost no clue how to do it properly, so I just blasted the solder pads with my heatgun until they melted and plopped the chip on there and slid it around until it seemed to be in the right place again
        • 20869
        Did you say heatgun.... do you mean a hot air station. I don`t think a stencil is available, the balls are 0.25mm according to the 2nd link,you could use a iphone or generic stencil,but its not going to be easy,or buy a new chip, and a hot air station if you don`t have one.
        http://advancedreworks.com/forum/arc...hp/t-1558.html
        https://www.rossmanngroup.com/boards...3437-no-camera
        • Flippers McCoy
          Tinkerer
          • Mar 2018
          • 106
          Yep, heat gun, as in one of these (attached). I'm looking into getting a nice Hakko rework station, but that's a little bit off for now :/
          Ahh, after reading those I think I understand what you mean. Also, they would suggest that this chip wouldn't stop the computer from turning on, right? I may as well just take it off and call the webcam a lost cause and continue to work on making the computer actually functional again
            • 20869
            Even a cheap chinese hot air station is better than a heat gun . TheQuick 861DW is a good station,and cheaper than hakko. My current station is an aoyue 852A+ ,still going strong after 6 years ,and a 858d as a backup.
            If you buy a new U3900 it will have solder balls on it.you need to clean up the old solder off the pads , with a decent soldering iron (don`t say you use a firestick..please)
            • Flippers McCoy
              Tinkerer
              • Mar 2018
              • 106
              I actually have the Quick 861DW on my A list for rework stations, that's the one I'm planning to buy when I round up the money. I got one similar to the aoyue 852A+, but it was absolute garbage. The rework gun was incapable of even melting solder, and if I raised the temperature too high the whole thing would shut off. I'm pretty sure I got a dud.
              I actually do have a legit soldering iron! It's an older Hakko, but it is definitely good. I was considering replacing it with a Hakko FM-203, but the Quick is first on my list so I can ditch the heat gun
              • Flippers McCoy
                Tinkerer
                • Mar 2018
                • 106
                Just for closure, I'm calling it a day on this job. Going to use the board as a donor board, should I need one.
                Thanks for the help, SMDFlea, much appreciated
                • Stevie2001
                  • Apr 2018
                  • 183
                  • irland
                  Well as far as i can se nobody here has either knowledge about what type of hot air is good as i dont se the text.
                  If you ever buy a hotair rework station get the ones with 23L
                  L stands for liter
                  Do not buy anything above 23L the lower you can get from 23l its good.
                  Anything above 23l will take long time to desolder or even toast your board,the heat is not equal and constant temp.
                  23l is very powerfull provides constant temp and heat it can take any ic or parts of in 3 4 seconds.
                  It can take intel chips off in 20 seconds or less i have it i know just letting you know what to buy.
                  • petehall347
                    • Jan 2015
                    • 4426
                    • United Kingdom
                    L stands for liter
                    just in time as considering one soon . .. heat guns destroy plastic connector surrounds . and get very hot . plus mine are broke anyway . surface mount is hard enough for me when i can see it .
                    • aidanmo
                      Philips 43PUS7506/12 - Loud blown out sound
                      by aidanmo
                      I've got a really strange issue with the speakers on my Philips 43PUS7506/12. It makes this awful loud buzzing now. It happened after it was attempted to be wall mounted - I think the back got squeezed and something broke.
                      I thought maybe the speakers got damaged, so I replaced them - no dice.
                      • Using the internal speakers, it always happens.
                      • Using the headphone jack, it never happens.
                      • Using the digital/optical out with a soundbar - it happens after about 2h/movie runtime - it's never as drastic, it just pops in and out, but I didn't want it to damage the sound bar
                      02-28-2025, 03:13 PM
                    • mon2
                      Crate guitar amp with extremely loud static on power on (no input)
                      by mon2
                      Hi. Not our mainstream line of work - we work with digital mostly. Will study the schematic found on the internet. The output darlington transistors appear to be ok. Even with no input, the output is extremely loud with static / crackle / pop. Any ideas? Will post more details and fix as we continue the review. Have not checked the main power supply rails yet (+-40V and +-16V).
                      07-18-2025, 06:40 AM
                    • justice171
                      Lenovo E15 Gen 2 Keeps Beeping Loud Noise
                      by justice171
                      Hello Badcaps Members,
                      I'm experiencing an issue with my Lenovo ThinkPad E15 Gen 2, and I'm hoping someone here might have some insight. The laptop charges to full capacity, but as soon as I power it up, I get a loud sound, and there's no POST.
                      I disconnected the battery and connected a USB meter, which shows 20V 0.23A when the sound occurs. I've already tried changing the screen, but it didn't resolve the issue.
                      When I use Lenovo PC Diagnostics App I get results as 01000
                      Here are the details:
                      • Model: Lenovo ThinkPad E15 Gen 2
                      • Board Numbe
                      10-01-2024, 09:19 PM
                    • eliemgh
                      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise
                      by eliemgh
                      lenovo t14 i7 10 gen : I press the power button and there is a loud fan noise for about 3 seconds and power light is on. Nothing on display screen. i have removed the battery and bios battery still the same. i have put yesterday on update and charger ,i have leave and back and see this problem. Any One Can help Me ?
                      09-27-2024, 02:40 AM
                    • Carm99
                      Citronic AC-1USB Output Too Loud
                      by Carm99
                      Hi
                      I have a Citronic AC-1USB.
                      When I run a turntable into it and then try to record it. The volume is too loud and distorting. In the red. Mainly 12” Singles. I haven’t tried a CD into it yet. I’m wondering if there is any way to bring the volume down inside the unit itself. Change a part or two. Put a small pot somewhere as there are no adjustments at all in there. I’m looking for the schematic but not found one yet.
                      Heres the circuit board inside.
                      Cheers
                      04-30-2024, 06:17 AM
